This tutorial describes how to import 3D meshes into Gazebo to increase the visual fidelity of your model. Continuing with our example, we'll attach a 3D mesh to our turtle, making it look much better.
Related tutorials
https://gazebosim.org/api/sim/8/meshtofuel.html
The next tutorials, although still relevant, are from an older version of Gazebo and some details might be different than the current versions:
https://classic.gazebosim.org/tutorials?tut=import_mesh&cat=build_robot https://classic.gazebosim.org/tutorials?cat=guided_i&tut=guided_i2
What is a visual?
The visual element specifies the shape used by the rendering engine. For most use cases the collision and visual elements are the same. The most common use for different collision and visual elements is to have a simplified collision element paired with a visual element that uses a complex mesh. This will help improve performance.
SDF supports the notion of visual as described here.
From our previous tutorial, the turtle visual is a cylinder. Let's use a COLLADA mesh instead.
Model directory structure
Gazebo has defined a model directory structure that supports stand-alone models, and the ability to share models via an online model database. Review this tutorial for more information.
Another benefit of Gazebo's model structure is that it conveniently organizes resources, such as mesh files, required by the model.
my_turtle
├── materials Directory for textures
└── textures
├── meshes Directory for mesh files such as COLLADA, STL, and Wavefront OBJ files
├── thumbnails Directory for preview images on Fuel
├── model.config Meta data about the model
└── model.sdf SDF description of the model
Create the directories to add the mesh and its texture:
mkdir -p ~/gazebo_maritime/models/my_turtle/meshes
mkdir -p ~/gazebo_maritime/models/my_turtle/materials/textures
Next, download the COLLADA mesh and its texture.
wget https://raw.githubusercontent.com/gazebosim/gz-sim/gz-sim8/tutorials/files/adding_visuals/turtle.dae -O ~/gazebo_maritime/models/my_turtle/meshes/turtle.dae
wget https://raw.githubusercontent.com/gazebosim/gz-sim/gz-sim8/tutorials/files/adding_visuals/Turtle_BaseColor.png -O ~/gazebo_maritime/models/my_turtle/materials/textures/Turtle_BaseColor.png
Now, let's edit our model.sdf to use the new mesh as our visual.
<?xml version="1.0" ?>
<sdf version="1.6">
<model name="turtle">
<link name="base_link">
<pose>0 0 0 0 0 0</pose>
<mass>10</mass>
<ixx>0.35032999999999995</ixx>
<iyy>0.35032999999999995</iyy>
<izz>0.61250000000000006</izz>
<collision name='collision'>
<size>1 1 0.009948450858321252</size>
<mesh>
<uri>meshes/turtle.dae</uri>
</mesh>
</sdf>
Load your model in Gazebo
Launch Gazebo and load our model:
gz sim ~/gazebo_maritime/models/my_turtle/model.sdf
You should see your model visualized as a mesh now!
