EnvironmentLoader Class Reference
A GUI plugin for a user to load an Environment component into the ECM on a live simulation. More...
#include <EnvironmentLoader.hh>
Signals
void DataPathChanged ()
 Notify that the path to the data file (potentially) changed. More...
void DimensionListChanged ()
 Notify that the list of dimensions has changed. More...
void IsConfiguredChanged ()
 Notify configuration status changed. More...
void ReferenceChanged () const
 Notify the spatial reference has changed. More...
void TimeIndexChanged () const
 Notify the time dimension index has changed. More...
void UnitChanged () const
 Notify the unit index has changed. More...
void XIndexChanged () const
 Notify the x dimension index has changed. More...
void YIndexChanged () const
 Notify the y dimension index has changed. More...
void ZIndexChanged () const
 Notify the z dimension index has changed. More...
 EnvironmentLoader ()
 ~EnvironmentLoader () override
Q_INVOKABLE QString DataPath () const
 Get path to the data file to be loaded. More...
Q_INVOKABLE QStringList DimensionList () const
 Get dimensions available in the data file. More...
Q_INVOKABLE bool IsConfigured () const
 Get configuration status. More...
Q_INVOKABLE QString Reference () const
 Get spatial reference. More...
Q_INVOKABLE QStringList ReferenceList () const
 Get supported spatial references. More...
Q_INVOKABLE void ScheduleLoad ()
 Schedule an update. More...
Q_INVOKABLE void SetDataPath (QString _dataPath)
 Set the path to the data file to be loaded. More...
Q_INVOKABLE void SetDataUrl (QUrl _dataUrl)
 Set the URL pointing to the data file to be loaded. More...
Q_INVOKABLE void SetReference (QString _reference)
 Set spatial reference. More...
Q_INVOKABLE void SetTimeIndex (int _timeIndex)
 Set index of the time dimension in the list. More...
Q_INVOKABLE void SetUnit (QString _unit)
 Set index of the unit in the list. More...
Q_INVOKABLE void SetXIndex (int _xIndex)
 Set index of the x dimension in the list. More...
Q_INVOKABLE void SetYIndex (int _yIndex)
 Set index of the y dimension in the list. More...
Q_INVOKABLE void SetZIndex (int _zIndex)
 Set index of the z dimension in the list. More...
Q_INVOKABLE int TimeIndex () const
 Get index of the time dimension in the list. More...
Q_INVOKABLE QString Unit () const
 Get index of the unit in the list. More...
Q_INVOKABLE QStringList UnitList () const
 Get available units. More...
void Update (const UpdateInfo &, EntityComponentManager &_ecm) override
 Update callback called every time the system is stepped. This is called at a Gazebo Transport thread, so any interaction with Qt should be done through signals and slots. More...
Q_INVOKABLE int XIndex () const
 Get index of the x dimension in the list. More...
Q_INVOKABLE int YIndex () const
 Get index of the y dimension in the list. More...
Q_INVOKABLE int ZIndex () const
 Get index of the z dimension in the list. More...
 Plugin ()
virtual ~Plugin ()
void PostParentChanges ()
Properties
bool configured
 Configuration ready. More...
QString dataPath
 Data path. More...
QStringList dimensionList
 Dimension list. More...
QString reference
 Spatial reference. More...
QStringList referenceList
 Spatial reference type list. More...
int timeIndex
 Time index. More...
QString unit
 Unit list. More...
QStringList unitList
 Unit list. More...
int xIndex
 X dimension. More...
int yIndex
 Y dimension. More...
int zIndex
 Z dimension. More...
void DeleteLater ()
std::string configStr
std::string title
gz/sim/systems/EnvironmentLoader.hh
◆ EnvironmentLoader()
◆ ~EnvironmentLoader()
~EnvironmentLoader ( )
◆ DataPath()
Q_INVOKABLE QString DataPath ( ) const
◆ DataPathChanged
void DataPathChanged ( )
signal
◆ DimensionList()
Q_INVOKABLE QStringList DimensionList ( ) const
◆ DimensionListChanged
void DimensionListChanged ( )
signal
◆ IsConfigured()
Q_INVOKABLE bool IsConfigured ( ) const
◆ IsConfiguredChanged
void IsConfiguredChanged ( )
signal
◆ LoadConfig()
Reimplemented from Plugin.
◆ Reference()
Q_INVOKABLE QString Reference ( ) const
◆ ReferenceChanged
void ReferenceChanged ( ) const
signal
◆ ReferenceList()
Q_INVOKABLE QStringList ReferenceList ( ) const
◆ ScheduleLoad()
Q_INVOKABLE void ScheduleLoad ( )
Schedule an update.
◆ SetDataPath()
Q_INVOKABLE void SetDataPath ( QString  _dataPath)
◆ SetDataUrl()
Q_INVOKABLE void SetDataUrl ( QUrl  _dataUrl)
◆ SetReference()
Q_INVOKABLE void SetReference ( QString  _reference)
◆ SetTimeIndex()
Q_INVOKABLE void SetTimeIndex ( int  _timeIndex)
◆ SetUnit()
Q_INVOKABLE void SetUnit ( QString  _unit)
◆ SetXIndex()
Q_INVOKABLE void SetXIndex ( int  _xIndex)
◆ SetYIndex()
Q_INVOKABLE void SetYIndex ( int  _yIndex)
◆ SetZIndex()
Q_INVOKABLE void SetZIndex ( int  _zIndex)
◆ TimeIndex()
Q_INVOKABLE int TimeIndex ( ) const
◆ TimeIndexChanged
void TimeIndexChanged ( ) const
signal
◆ Unit()
Q_INVOKABLE QString Unit ( ) const
◆ UnitChanged
void UnitChanged ( ) const
signal
◆ UnitList()
Q_INVOKABLE QStringList UnitList ( ) const
Reimplemented from GuiSystem.
◆ XIndex()
Q_INVOKABLE int XIndex ( ) const
◆ XIndexChanged
void XIndexChanged ( ) const
signal
◆ YIndex()
Q_INVOKABLE int YIndex ( ) const
◆ YIndexChanged
void YIndexChanged ( ) const
signal
◆ ZIndex()
Q_INVOKABLE int ZIndex ( ) const
◆ ZIndexChanged
void ZIndexChanged ( ) const
signal
Property Documentation
◆ configured
bool configured
read
◆ dataPath
QString dataPath
readwrite
Data path.
◆ dimensionList
read
Dimension list.
◆ reference
QString reference
readwrite
Spatial reference.
◆ referenceList
read
◆ timeIndex
int timeIndex
readwrite
Time index.
◆ unit
QString unit
readwrite
Unit list.
◆ unitList
read
Unit list.
◆ xIndex
int xIndex
readwrite
X dimension.
◆ yIndex
int yIndex
readwrite
Y dimension.
◆ zIndex
int zIndex
readwrite
Z dimension.
