GlobalIlluminationCiVct Class Reference
Enable and configure Global Illumination using CIVCT (Cascaded Image Voxel Cone Tracing) More...
#include <GlobalIlluminationCiVct.hh>
Signals
void CameraListChanged ()
 Notify camera list has changed. More...
void CascadesEditableChanged ()
 Notify this property has changed. More...
void DebugVisualizationModeChanged ()
 Notify debug visualization has changed. More...
void EnabledChanged ()
void LightingChanged ()
 Notify fast-to-rebuild properties may have changed. More...
void qmlAddCascade ()
 Tells QML to add a cascade from UI thread. MUST start lowercase. More...
void qmlAddCascade2 (quint32 _resX, quint32 _resY, quint32 _resZ, quint32 _octX, quint32 _octY, quint32 _octZ, float _ahsX, float _ahsY, float _ahsZ, float _thinWallCounter)
void SettingsChanged ()
 Notify various properties may have changed. More...
 GlobalIlluminationCiVct ()
 ~GlobalIlluminationCiVct () override
Q_INVOKABLE QObject * AddCascade ()
 Adds a new cascade based on the previous one (if there's any) More...
Q_INVOKABLE bool Anisotropic () const
 See rendering::GlobalIlluminationCiVct::Anisotropic. More...
Q_INVOKABLE uint32_t BounceCount () const
 See rendering::GlobalIlluminationCiVct::BounceCount. More...
Q_INVOKABLE QStringList CameraList ()
 Populates available cameras. More...
Q_INVOKABLE bool CascadesEditable () const
 Returns true when it's possible to add/remove cascades False when it's not. More...
Q_INVOKABLE uint32_t DebugVisualizationMode () const
 See rendering::GlobalIlluminationCiVct::DebugVisualizationMode. More...
Q_INVOKABLE bool Enabled () const
 See rendering::GlobalIlluminationCiVct::Enabled. More...
Q_INVOKABLE QObject * GetCascade (int _idx) const
 Retrieves an existing cascade. More...
Q_INVOKABLE bool HighQuality () const
 See rendering::GlobalIlluminationCiVct::HighQuality. More...
bool LoadGlobalIlluminationCiVct ()
 Load the scene and attach LidarVisual to the scene. More...
Q_INVOKABLE void OnCamareBind (const QString &_cameraName)
 Binds the given camera as active for the center of all cascades. More...
Q_INVOKABLE void OnRefreshCameras ()
Q_INVOKABLE void PopCascade ()
 Pops the last created cascade. More...
Q_INVOKABLE void ResetCascades ()
 Disables this GI solution and makes cascades editable again. More...
Q_INVOKABLE void SetAnisotropic (const bool _anisotropic)
 See rendering::GlobalIlluminationCiVct::SetAnisotropic. More...
Q_INVOKABLE void SetBounceCount (const uint32_t _bounces)
 See rendering::GlobalIlluminationCiVct::SetBounceCount. More...
Q_INVOKABLE void SetDebugVisualizationMode (const uint32_t _visMode)
 See rendering::GlobalIlluminationCiVct::SetDebugVisualizationMode. More...
Q_INVOKABLE bool SetEnabled (const bool _enabled)
 See rendering::GlobalIlluminationCiVct::SetEnabled & rendering::Scene::SetActiveGlobalIllumination. More...
Q_INVOKABLE void SetHighQuality (const bool _quality)
 See rendering::GlobalIlluminationCiVct::SetHighQuality. More...
Q_INVOKABLE void UpdateDebugVisualizationMode (int _mode)
 Set debug visualization mode GlogbalIllumination. More...
- Public Member Functions inherited from GuiSystem
virtual void Update (const UpdateInfo &_info, EntityComponentManager &_ecm)
 Update callback called every time the system is stepped. This is called at a Gazebo Transport thread, so any interaction with Qt should be done through signals and slots. More...
 Plugin ()
virtual ~Plugin ()
void PostParentChanges ()
Properties
bool anisotropic
int bounceCount
QStringList cameraList
bool cascadesEditable
int debugVisualizationMode
bool enabled
 Enabled QML binding. Anything that isn't GUI-only (i.e. affects simulation) needs it. More...
bool highQuality
void DeleteLater ()
std::string configStr
std::string title
◆ GlobalIlluminationCiVct()
◆ ~GlobalIlluminationCiVct()
~GlobalIlluminationCiVct ( )
◆ AddCascade()
Q_INVOKABLE QObject* AddCascade ( )
A CiVctCascade ptr to be used by QML
◆ Anisotropic()
Q_INVOKABLE bool Anisotropic ( ) const
◆ BounceCount()
Q_INVOKABLE uint32_t BounceCount ( ) const
◆ CameraList()
Q_INVOKABLE QStringList CameraList ( )
◆ CameraListChanged
void CameraListChanged ( )
signal
◆ CascadesEditable()
Q_INVOKABLE bool CascadesEditable ( ) const
True if cascades can be added/removed
◆ CascadesEditableChanged
void CascadesEditableChanged ( )
signal
◆ DebugVisualizationMode()
Q_INVOKABLE uint32_t DebugVisualizationMode ( ) const
◆ DebugVisualizationModeChanged
void DebugVisualizationModeChanged ( )
signal
◆ Enabled()
Q_INVOKABLE bool Enabled ( ) const
◆ EnabledChanged
void EnabledChanged ( )
signal
◆ eventFilter()
QEvent *  _event
◆ GetCascade()
Q_INVOKABLE QObject* GetCascade ( int  _idx) const
_idxIndex of the cascade. Must be in range (you must track how many times AddCascade() & PopCascade() has been called).
◆ HighQuality()
Q_INVOKABLE bool HighQuality ( ) const
◆ LightingChanged
void LightingChanged ( )
signal
◆ LoadConfig()
Reimplemented from Plugin.
◆ LoadGlobalIlluminationCiVct()
bool LoadGlobalIlluminationCiVct ( )
True if GI CIVCT is loaded successfully, false otherwise.
◆ OnCamareBind()
Q_INVOKABLE void OnCamareBind ( const QString &  _cameraName)
[in]_cameraNameName of an existing camera to track Currently it must be a Camera in the GUI. In the future something more advanced to synchronize with Server will be needed.
◆ OnRefreshCameras()
Q_INVOKABLE void OnRefreshCameras ( )
◆ PopCascade()
Q_INVOKABLE void PopCascade ( )
◆ qmlAddCascade
void qmlAddCascade ( )
signal
◆ qmlAddCascade2
void qmlAddCascade2 ( quint32  _resX,
quint32  _resY,
quint32  _resZ,
quint32  _octX,
quint32  _octY,
quint32  _octZ,
float  _ahsX,
float  _ahsY,
float  _ahsZ,
signal
[in]_resXResolution X
[in]_resYResolution Y
[in]_resZResolution Z
[in]_octXOctant Count X
[in]_octYOctant Count Y
[in]_octZOctant Count Z
[in]_ahsXArea Half Size X
[in]_ahsYArea Half Size Y
[in]_ahsZArea Half Size Z
[in]_thinWallCounterthinWallCounter parameter
◆ ResetCascades()
Q_INVOKABLE void ResetCascades ( )
◆ SetAnisotropic()
Q_INVOKABLE void SetAnisotropic ( const bool  _anisotropic)
[in]_anisotropicSee GlobalIlluminationCiVct::SetAnisotropic
◆ SetBounceCount()
Q_INVOKABLE void SetBounceCount ( const uint32_t  _bounces)
[in]_bouncesSee GlobalIlluminationCiVct::SetBounceCount
◆ SetDebugVisualizationMode()
Q_INVOKABLE void SetDebugVisualizationMode ( const uint32_t  _visMode)
[in]_visModeSee GlobalIlluminationCiVct::SetDebugVisualizationMode
◆ SetEnabled()
Q_INVOKABLE bool SetEnabled ( const bool  _enabled)
[in]_enabledSee GlobalIlluminationCiVct::SetEnabled
The new setting. We may fail to enable if settings are invalid See ValidSettings()
◆ SetHighQuality()
Q_INVOKABLE void SetHighQuality ( const bool  _quality)
[in]_qualitySee GlobalIlluminationCiVct::SetHighQuality
◆ SettingsChanged
void SettingsChanged ( )
signal
◆ UpdateDebugVisualizationMode()
Q_INVOKABLE void UpdateDebugVisualizationMode ( int  _mode)
[in]_modeIndex of selected debug visualization mode
Property Documentation
◆ anisotropic
bool anisotropic
readwrite
◆ bounceCount
int bounceCount
readwrite
◆ cameraList
read
◆ cascadesEditable
read
◆ debugVisualizationMode
readwrite
◆ enabled
bool enabled
readwrite
◆ highQuality
bool highQuality
readwrite
