GlobalIlluminationVct Class Reference
Enable and configure Global Illumination using VCT (Voxel Cone Tracing) More...
#include <GlobalIlluminationVct.hh>
Signals
void DebugVisualizationModeChanged ()
 Notify debug visualization has changed. More...
void EnabledChanged ()
 Notify this property has changed. More...
void LightingChanged ()
 Notify fast-to-rebuild properties may have changed. More...
void SettingsChanged ()
 Notify various properties may have changed. More...
 GlobalIlluminationVct ()
 ~GlobalIlluminationVct () override
Q_INVOKABLE bool Anisotropic () const
 See rendering::GlobalIlluminationVct::Anisotropic. More...
Q_INVOKABLE uint32_t BounceCount () const
 See rendering::GlobalIlluminationVct::BounceCount. More...
Q_INVOKABLE bool ConserveMemory () const
 See rendering::GlobalIlluminationVct::ConserveMemory. More...
Q_INVOKABLE uint32_t DebugVisualizationMode () const
 See rendering::GlobalIlluminationVct::DebugVisualizationMode. More...
Q_INVOKABLE bool Enabled () const
 See rendering::GlobalIlluminationVct::Enabled. More...
Q_INVOKABLE bool HighQuality () const
 See rendering::GlobalIlluminationVct::HighQuality. More...
bool LoadGlobalIlluminationVct ()
 Load the scene and attach LidarVisual to the scene. More...
Q_INVOKABLE uint32_t OctantCountX () const
 See rendering::GlobalIlluminationVct::OctantCount. More...
Q_INVOKABLE uint32_t OctantCountY () const
Q_INVOKABLE uint32_t OctantCountZ () const
Q_INVOKABLE uint32_t ResolutionX () const
 See rendering::GlobalIlluminationVct::Resolution. More...
Q_INVOKABLE uint32_t ResolutionY () const
Q_INVOKABLE uint32_t ResolutionZ () const
Q_INVOKABLE void SetAnisotropic (const bool _anisotropic)
 See rendering::GlobalIlluminationVct::SetAnisotropic. More...
Q_INVOKABLE void SetBounceCount (const uint32_t _bounces)
 See rendering::GlobalIlluminationVct::SetBounceCount. More...
Q_INVOKABLE void SetConserveMemory (const bool _conserveMemory)
 See rendering::GlobalIlluminationVct::SetConserveMemory. More...
Q_INVOKABLE void SetDebugVisualizationMode (const uint32_t _visMode)
 See rendering::GlobalIlluminationVct::SetDebugVisualizationMode. More...
Q_INVOKABLE void SetEnabled (const bool _enabled)
 See rendering::GlobalIlluminationVct::SetEnabled & rendering::Scene::SetActiveGlobalIllumination. More...
Q_INVOKABLE void SetHighQuality (const bool _quality)
 See rendering::GlobalIlluminationVct::SetHighQuality. More...
Q_INVOKABLE void SetOctantCountX (const uint32_t _octantCount)
 See rendering::GlobalIlluminationVct::SetOctantCount. More...
Q_INVOKABLE void SetOctantCountY (const uint32_t _octantCount)
Q_INVOKABLE void SetOctantCountZ (const uint32_t _octantCount)
Q_INVOKABLE void SetResolutionX (const uint32_t _res)
 See rendering::GlobalIlluminationVct::SetResolution. More...
Q_INVOKABLE void SetResolutionY (const uint32_t _res)
Q_INVOKABLE void SetResolutionZ (const uint32_t _res)
Q_INVOKABLE void SetThinWallCounter (const float _thinWallCounter)
 See rendering::GlobalIlluminationVct::SetThinWallCounter. More...
Q_INVOKABLE float ThinWallCounter () const
 See rendering::GlobalIlluminationVct::ThinWallCounter. More...
Q_INVOKABLE void UpdateDebugVisualizationMode (int _mode)
 Set debug visualization mode GlogbalIllumination. More...
Q_INVOKABLE void UpdateOctantCount (int _axis, uint32_t _count)
 Set VCT octant count. More...
Q_INVOKABLE void UpdateResolution (int _axis, uint32_t _res)
 Set VCT resolution. More...
- Public Member Functions inherited from GuiSystem
virtual void Update (const UpdateInfo &_info, EntityComponentManager &_ecm)
 Update callback called every time the system is stepped. This is called at a Gazebo Transport thread, so any interaction with Qt should be done through signals and slots. More...
 Plugin ()
virtual ~Plugin ()
void PostParentChanges ()
Properties
bool anisotropic
int bounceCount
bool conserveMemory
int debugVisualizationMode
bool enabled
 Enabled QML binding. Anything that isn't GUI-only (i.e. affects simulation) needs it. More...
bool highQuality
int octantCountX
int octantCountY
int octantCountZ
int resolutionX
int resolutionY
int resolutionZ
float thinWallCounter
void DeleteLater ()
std::string configStr
std::string title
Due to how QML bindings work, we must split Vectors into each component so e.g. the following Javascript code:
cascade.resolutionX = 16 cascade.resolutionY = 32 cascade.resolutionZ = 64
Will end up calling:
cascade->SetResolutionX(16); cascade->SetResolutionY(32); cascade->SetResolutionZ(64);
Even though in C++ we would normally do resolution = {16, 32, 64}; The same goes for each property.
◆ GlobalIlluminationVct()
◆ ~GlobalIlluminationVct()
~GlobalIlluminationVct ( )
◆ Anisotropic()
Q_INVOKABLE bool Anisotropic ( ) const
◆ BounceCount()
Q_INVOKABLE uint32_t BounceCount ( ) const
◆ ConserveMemory()
Q_INVOKABLE bool ConserveMemory ( ) const
◆ DebugVisualizationMode()
Q_INVOKABLE uint32_t DebugVisualizationMode ( ) const
◆ DebugVisualizationModeChanged
void DebugVisualizationModeChanged ( )
signal
◆ Enabled()
Q_INVOKABLE bool Enabled ( ) const
◆ EnabledChanged
void EnabledChanged ( )
signal
◆ eventFilter()
QEvent *  _event
◆ HighQuality()
Q_INVOKABLE bool HighQuality ( ) const
◆ LightingChanged
void LightingChanged ( )
signal
◆ LoadConfig()
Reimplemented from Plugin.
◆ LoadGlobalIlluminationVct()
bool LoadGlobalIlluminationVct ( )
True if GI VCT is loaded successfully, false otherwise.
◆ OctantCountX()
Q_INVOKABLE uint32_t OctantCountX ( ) const
◆ OctantCountY()
Q_INVOKABLE uint32_t OctantCountY ( ) const
◆ OctantCountZ()
Q_INVOKABLE uint32_t OctantCountZ ( ) const
◆ ResolutionX()
Q_INVOKABLE uint32_t ResolutionX ( ) const
◆ ResolutionY()
Q_INVOKABLE uint32_t ResolutionY ( ) const
◆ ResolutionZ()
Q_INVOKABLE uint32_t ResolutionZ ( ) const
◆ SetAnisotropic()
Q_INVOKABLE void SetAnisotropic ( const bool  _anisotropic)
[in]_anisotropicSee GlobalIlluminationVct::SetAnisotropic
◆ SetBounceCount()
Q_INVOKABLE void SetBounceCount ( const uint32_t  _bounces)
[in]_bouncesSee GlobalIlluminationVct::SetBounceCount
◆ SetConserveMemory()
Q_INVOKABLE void SetConserveMemory ( const bool  _conserveMemory)
[in]_conserveMemorySee GlobalIlluminationVct::SetConserveMemory
◆ SetDebugVisualizationMode()
Q_INVOKABLE void SetDebugVisualizationMode ( const uint32_t  _visMode)
[in]_visModeSee GlobalIlluminationVct::SetDebugVisualizationMode
◆ SetEnabled()
Q_INVOKABLE void SetEnabled ( const bool  _enabled)
[in]_enabledSee GlobalIlluminationVct::SetEnabled
◆ SetHighQuality()
Q_INVOKABLE void SetHighQuality ( const bool  _quality)
[in]_qualitySee GlobalIlluminationVct::SetHighQuality
◆ SetOctantCountX()
Q_INVOKABLE void SetOctantCountX ( const uint32_t  _octantCount)
[in]_octantCountSee GlobalIlluminationVct::SetOctantCount
◆ SetOctantCountY()
Q_INVOKABLE void SetOctantCountY ( const uint32_t  _octantCount)
◆ SetOctantCountZ()
Q_INVOKABLE void SetOctantCountZ ( const uint32_t  _octantCount)
◆ SetResolutionX()
Q_INVOKABLE void SetResolutionX ( const uint32_t  _res)
[in]_resSee GlobalIlluminationVct::SetResolution
◆ SetResolutionY()
Q_INVOKABLE void SetResolutionY ( const uint32_t  _res)
◆ SetResolutionZ()
Q_INVOKABLE void SetResolutionZ ( const uint32_t  _res)
◆ SetThinWallCounter()
Q_INVOKABLE void SetThinWallCounter ( const float  _thinWallCounter)
[in]_thinWallCounterSee GlobalIlluminationVct::SetThinWallCounter
◆ SettingsChanged
void SettingsChanged ( )
signal
◆ ThinWallCounter()
Q_INVOKABLE float ThinWallCounter ( ) const
◆ UpdateDebugVisualizationMode()
Q_INVOKABLE void UpdateDebugVisualizationMode ( int  _mode)
[in]_modeIndex of selected debug visualization mode
◆ UpdateOctantCount()
Q_INVOKABLE void UpdateOctantCount ( int  _axis,
uint32_t  _count
[in]_axisAxis (width, height, depth). In range [0; 3)
[in]_countNew octant count
◆ UpdateResolution()
Q_INVOKABLE void UpdateResolution ( int  _axis,
uint32_t  _res
Set VCT resolution.
[in]_resNew resolution
Property Documentation
◆ anisotropic
bool anisotropic
readwrite
◆ bounceCount
int bounceCount
readwrite
◆ conserveMemory
bool conserveMemory
readwrite
◆ debugVisualizationMode
readwrite
◆ enabled
bool enabled
readwrite
◆ highQuality
bool highQuality
readwrite
◆ octantCountX
int octantCountX
readwrite
◆ octantCountY
int octantCountY
readwrite
◆ octantCountZ
int octantCountZ
readwrite
◆ resolutionX
int resolutionX
readwrite
◆ resolutionY
int resolutionY
readwrite
◆ resolutionZ
int resolutionZ
readwrite
◆ thinWallCounter
readwrite
