PlotComponent Class Reference
A container of the component data that keeps track of the registered attributes and update their values and their registered charts. More...
#include <Plotting.hh>
 PlotComponent (const std::string &_type, Entity _entity, ComponentTypeId _typeId)
 ~PlotComponent ()
std::map< std::string, std::shared_ptr< gz::gui::PlotData > > Data () const
 Get all attributes of the component. More...
Entity Entity ()
 Get the Component entity ID. More...
bool HasCharts ()
 Check if any of the component attributes has any chart. More...
void RegisterChart (std::string _attribute, int _chart)
 Add a registered chart to the attribute. More...
void SetAttributeValue (std::string _attribute, const double &_value)
 Set a value of specefic component attribute. More...
ComponentTypeId TypeId ()
 Get the Component type ID. More...
void UnRegisterChart (std::string _attribute, int _chart)
 Remove a registered chart from the attribute. More...
◆ PlotComponent()
PlotComponent ( const std::string &  _type,
Entity  _entity,
[in]_typecomponent data type (Pose3d, Vector3d, double)
[in]_entityentity id of that component
[in]_typeIdtype identifier unique to each component type
◆ ~PlotComponent()
◆ Data()
◆ Entity()
Entity ID
◆ HasCharts()
bool HasCharts ( )
true if any attribute has a chart false if all attributes are empty from the charts
◆ RegisterChart()
void RegisterChart ( std::string  _attribute,
int  _chart
[in]_attributecomponent attribute to add the chart to it
[in]_chartchart ID to be added to the attribute
◆ SetAttributeValue()
void SetAttributeValue ( std::string  _attribute,
const double &  _value
[in]_attributecomponent attribute to set its value ex : yaw attribute in Pose3d type Component
[in]_valuevalue to be set to the attribute
◆ TypeId()
ComponentTypeId TypeId ( )
component type ID
◆ UnRegisterChart()
void UnRegisterChart ( std::string  _attribute,
int  _chart
[in]_attributecomponent attribute to remove the chart from it
[in]_chartchart ID to be removed from the attribute
