AckermannSteering Class Reference
Ackermann steering controller which can be attached to a model with any number of left and right wheels. More...
#include <AckermannSteering.hh>
 AckermannSteering ()
 ~AckermannSteering () override=default
 Configure the system. More...
  • <steering_only>: Boolean used to only control the steering angle only. Calculates the angles of wheels from steering_limit, wheel_base, and wheel_separation. Uses gz::msg::Double on default topic name /model/{name_of_model}/steer_angle. Automatically set True when <use_actuator_msg> is True, uses defaults topic name "/actuators".
  • <use_actuator_msg> True to enable the use of actuator message for steering angle command. Relies on <actuator_number> for the index of the position actuator and defaults to topic "/actuators".
  • <actuator_number> used with <use_actuator_msg> to set the index of the steering angle position actuator.
  • <steer_p_gain>: Float used to control the steering angle P gain.
  • <left_joint>: Name of a joint that controls a left wheel. This element can appear multiple times, and must appear at least once.
  • <right_joint>: Name of a joint that controls a right wheel. This element can appear multiple times, and must appear at least once.
  • <left_steering_joint>: Name of a joint that controls steering for left wheel. This element must appear once. Vehicles that steer rear wheels are not currently correctly supported.
  • <right_steering_joint>: Name of a joint that controls steering for right wheel. This element must appear once.
  • <wheel_separation>: Distance between wheels, in meters. This element is optional, although it is recommended to be included with an appropriate value. The default value is 1.0m.
  • <kingpin_width>: Distance between wheel kingpins, in meters. This element is optional, although it is recommended to be included with an appropriate value. The default value is 0.8m. Generally a bit smaller than the wheel_separation.
  • <wheel_base>: Distance between front and rear wheels, in meters. This element is optional, although it is recommended to be included with an appropriate value. The default value is 1.0m.
  • <steering_limit>: Value to limit steering to. Can be calculated by measuring the turning radius and wheel_base of the real vehicle. steering_limit = asin(wheel_base / turning_radius) The default value is 0.5 radians.
  • <wheel_radius>: Wheel radius in meters. This element is optional, although it is recommended to be included with an appropriate value. The default value is 0.2m.
  • <odom_publish_frequency>: Odometry publication frequency. This element is optional, and the default value is 50Hz.
  • <min_velocity>: Minimum velocity [m/s], usually <= 0.
  • <max_velocity>: Maximum velocity [m/s], usually >= 0.
  • <min_acceleration>: Minimum acceleration [m/s^2], usually <= 0.
  • <max_acceleration>: Maximum acceleration [m/s^2], usually >= 0.
  • <min_jerk Minimum>: jerk [m/s^3], usually <= 0.
  • <max_jerk Maximum>: jerk [m/s^3], usually >= 0.
  • <topic>: Custom topic that this system will subscribe to in order to receive command messages. This element is optional, and the default value is /model/{name_of_model}/cmd_vel or when steering_only is true /model/{name_of_model}/steer_angle.
  • <sub_topic>: Custom sub_topic that this system will subscribe to in order to receive command messages. This element is optional, and creates a topic /model/{name_of_model}/{sub_topic}
  • <odom_topic>: Custom topic on which this system will publish odometry messages. This element if optional, and the default value is /model/{name_of_model}/odometry.
  • <tf_topic>: Custom topic on which this system will publish the transform from frame_id to child_frame_id. This element is optional, and the default value is /model/{name_of_model}/tf.
  • <frame_id>: Custom frame_id field that this system will use as the origin of the odometry transform in both the <tf_topic> gz.msgs.Pose_V message and the <odom_topic> gz.msgs.Odometry message. This element if optional, and the default value is {name_of_model}/odom.
  • <child_frame_id>: Custom child_frame_id that this system will use as the target of the odometry transform in both the <tf_topic> gz.msgs.Pose_V message and the <odom_topic> gz.msgs.Odometry message. This element is optional, and the default value is {name_of_model}/{name_of_link}.
A robot with rear drive and front steering would have one each of left_joint, right_joint, left_steering_joint and right_steering_joint.
References:
◆ AckermannSteering()
◆ ~AckermannSteering()
~AckermannSteering ( )
overridedefault
◆ PostUpdate()
