AcousticComms Class Reference
A comms model that simulates communication using acoustic devices. The model uses simple distance based acoustics model. More...
#include <AcousticComms.hh>
 AcousticComms ()
 ICommsModel ()
 Configure the system. More...
This system can be configured with the following SDF parameters:
  • Optional parameters:
    • <max_range>: Hard limit on range (meters). No communication will happen beyond this range. Default is 1000.
    • <speed_of_sound>: Speed of sound in the medium (meters/sec). Default is 343.0
    • <collision_time_per_byte> : If a subscriber receives a message 'b' bytes long at time 't0', it won't receive and other message till time : 't0 + b * collision_time_per_byte'. Defaults to zero.
    • <collision_time_packet_drop> : If a packet is dropped at time t0, the next packet won't be received until time t0 + collision_time_packet_drop. Defaults to zero.
    • <propagation_model> : Enables the use of propagation model. Disabled by default.
      • <source_power> : Source power at the transmitter in Watts. Defaults to 2 kW.
      • <noise_level> : Ratio of the noise intensity at the receiver to the same reference intensity used for source level. Defaults to 1.
      • <spectral_efficiency> : Information rate that can be transmitted over a given bandwidth in a specific communication system, in (bits/sec)/Hz. Defaults to 7 bits/sec/Hz.
      • <seed> : Seed value to be used for random sampling.
Here's an example:
filename="gz-sim-acoustic-comms-system"
name="systems::AcousticComms">
<max_range>500</max_range>
<speed_of_sound>1400</speed_of_sound>
<collision_time_per_byte>0.001</collision_time_per_byte>
<collision_time_packet_drop>0.001</collision_time_packet_drop>
<propagation_model>
<source_power>2000</source_power>
<noise_level>1</noise_level>
<spectral_efficiency>7</spectral_efficiency>
</propagation_model>
◆ AcousticComms()
AcousticComms ( )
◆ Load()
Implements ICommsModel.
◆ Step()
[in]_ecm- Gazebo Sim's ECM.
