EntitySemantics Class Reference
System for assigning semantics to entities, such as models, by classifying them into categories and assigning them tags. Reference: https://github.com/ros-simulation/simulation_interfaces/blob/main/msg/EntityInfo.msg, https://github.com/ros-simulation/simulation_interfaces/blob/main/msg/EntityCategory.msg, https://github.com/ros-simulation/simulation_interfaces/blob/main/msg/TagsFilter.msg. More...
#include <EntitySemantics.hh>
This system is meant to be attached to a <world>, but it parses parameters found in entities such as models.
Entity Parameters
  • <gz:semantics>: Root element to be specified inside entities, e.g. <model>. It has the following child parameters:
    • <category>: string representation of the value as defined in https://github.com/ros-simulation/simulation_interfaces/blob/1.0.0/msg/EntityCategory.msg. The string is formed by removing the prefix CATEGORY_ from the categories listed in the EntityCategory message. Example: for CATEGORY_ROBOT, it would be <category>ROBOT</category>. Lowercase values will also be accepted. There can only be one instance of the <category> element for an entity.
    • <tag>: string labels that can be assigned according to the user's classification scheme. They serve as a secondary layer of classification in on top of categories. Multiple instances of the <tag> elements are allowed for an entity.
    • <description>: freeform string that describes the entity. There can only be one instance of the <description> element for an entity.
Example:
<model name="robot1">
<gz:semantics>
<tag>mobile</tag>
<tag>diff_drive</tag>
<description>Food delivery mobile robot</description>
</gz:semantics>
