JointStatePublisher Class Reference
The JointStatePublisher system publishes joint state information for a model. The published message type is gz::msgs::Model, and the publication topic is determined by the <topic> parameter. More...
#include <JointStatePublisher.hh>
 JointStatePublisher ()
 ~JointStatePublisher () override=default
void Configure (const Entity &_entity, const std::shared_ptr< const sdf::Element > &, EntityComponentManager &_ecm, EventManager &) override
 Configure the system. More...
By default the JointStatePublisher will publish all joints for a model. Use the <joint_name> system parameter, described below, to control which joints are published.
  • <topic>: Name of the topic to publish to. This parameter is optional, and if not provided, the joint state will be published to "/world/<world_name>/model/<model_name>/joint_state".
  • <joint_name>: Name of a joint to publish. This parameter can be specified multiple times, and is optional. All joints in a model will be published if joint names are not specified.
  • <update_rate>: Maximum publication frequency in Hz. Optional. Values > 0 throttle publications using sim time. If absent or set to 0, publish every simulation iteration.
◆ JointStatePublisher()
◆ ~JointStatePublisher()
~JointStatePublisher ( )
overridedefault
◆ PostUpdate()
finalvirtual
