KineticEnergyMonitor Class Referencefinal
A system that monitors the kinetic energy of a link in a model and publishes when there is a lost of kinetic energy during a timestep that surpasses a specific threshold. This system can be used to detect when a model could be damaged. More...
#include <KineticEnergyMonitor.hh>
 KineticEnergyMonitor ()
 ~KineticEnergyMonitor () final
 Configure the system. More...
  • <link_name>: Name of the link to monitor. This name must match a name of link within the model.
  • <kinetic_energy_threshold>: Threshold, in Joule (J), after which a message is generated on <topic> with the kinetic energy value that surpassed the threshold.
  • <topic>: Custom topic that this system will publish to when kinetic energy surpasses the threshold. This element if optional, and the default value is /model/{name_of_model}/kinetic_energy.
Example Usage
 <model name="sphere">
    <pose>0 0 5 0 0 0</pose>
    <link name="sphere_link">
          <ixx>3</ixx>
          <iyy>3</iyy>
          <izz>3</izz>
        <mass>3.0</mass>
      <collision name="sphere_collision">
          <sphere>
            <radius>0.5</radius>
          </sphere>
      <visual name="sphere_visual">
          <sphere>
          </sphere>
          <ambient>0 0 1 1</ambient>
          <diffuse>0 0 1 1</diffuse>
          <specular>0 0 1 1</specular>
      filename="gz-sim-kinetic-energy-monitor-system"
      name="systems::KineticEnergyMonitor">
      <base_link_name>sphere_link</base_link_name>
      <kinetic_energy_threshold>100</kinetic_energy_threshold>
◆ KineticEnergyMonitor()
◆ ~KineticEnergyMonitor()
finalvirtual
◆ PostUpdate()
finalvirtual
