LighterThanAirDynamics Class Reference
This class provides the effect of viscousity on the hull of lighter-than-air vehicles such as airships. The equations implemented is based on the work published in [1], which describes a modeling approach for the nonlinear dynamics simulation of airships and [2] providing more insight of the modelling of an airship. More...
#include <LighterThanAirDynamics.hh>
 LighterThanAirDynamics ()
 ~LighterThanAirDynamics () override
math::Vector3d AddedMassForce (math::Vector3d lin_vel, math::Vector3d ang_vel, math::Matrix3d m11, math::Matrix3d m12)
 Calculates the potential flow aerodynamic torques that a LTA vehicle experience when moving in a potential fluid. The aerodynamic torques is derived using Kirchoff's equation. More...
math::Vector3d AddedMassTorque (math::Vector3d lin_vel, math::Vector3d ang_vel, math::Matrix3d m11, math::Matrix3d m12, math::Matrix3d m21, math::Matrix3d m22)
 Calculates the potential flow aerodynamic forces that a LTA vehicle experience when moving in a potential fluid. The aerodynamic force is derived using Kirchoff's equation. More...
double DynamicPressure (math::Vector3d vec, double air_density)
 Calculates dynamic pressure. More...
math::Vector3d LocalVelocity (math::Vector3d lin_vel, math::Vector3d ang_vel, math::Vector3d dist)
 Calculates the local velocity at an offset from a origin. More...
math::Matrix3d SkewSymmetricMatrix (math::Vector3d mat)
 Skew-symmetric matrices can be used to represent cross products as matrix multiplications. More...
  • <air_density> sets the density of air that surrounds the buoyant object. [Units: kgm^-3]
  • <force_invisc_coeff is the first coefficient in Eq (11) in [1]: \( (k_2 - k_1) \cdot \int_{\varepsilon_{0}}^{L} \frac{dS}{d\varepsilon} \,d\varepsilon \)
  • <force_visc_coeff> is the second coefficient in Eq (11) in [1]: \( \eta C_{DC} \cdot \int_{\varepsilon_{0}}^{L} 2R \,d\varepsilon \)
  • <moment_invisc_coeff is the first coefficient in Eq (14) in [1]: \( (k_2 - k_1) \cdot \int_{\varepsilon_{0}}^{L} \frac{dS}{d\varepsilon} (\varepsilon_{m} - \varepsilon) \,d\varepsilon \)
  • <moment_visc_coeff> is the second coefficient in Eq (14) in [1]: \( \eta C_{DC} \cdot \int_{\varepsilon_{0}}^{L} 2R (\varepsilon_{m} - \varepsilon) \,d\varepsilon \)
  • <eps_v> is the point on the hull where the flow ceases being potential
  • <axial_drag_coeff> the actual drag coefficient of the hull
Notes
This class only implements the viscous effects on the hull of an airship and currently does not take into the account wind. This class should be used in combination with the boyuancy, added mass and gravity plugins to simulate the behaviour of an airship. Its important to provide a collision property to the hull, since this is from which the buoyancy plugin determines the volume.
Citations
[1] Li, Y., & Nahon, M. (2007). Modeling and simulation of airship dynamics. Journal of Guidance, Control, and Dynamics, 30(6), 1691–1700.
[2] Li, Y., Nahon, M., & Sharf, I. (2011). Airship dynamics modeling: A literature review. Progress in Aerospace Sciences, 47(3), 217–239.
◆ LighterThanAirDynamics()
◆ ~LighterThanAirDynamics()
~LighterThanAirDynamics ( )
◆ AddedMassForce()
math::Vector3d AddedMassForce ( math::Vector3d  lin_vel,
math::Matrix3d  m11,
math::Matrix3d  m12
[in]lin_vel- The body linear velocity
[in]ang_vel- The body angular velocity
[in]m11- The left upper [3x3] matrix of the added mass matrix
[in]m12- The right upper [3x3] matrix of the added mass matrix
◆ AddedMassTorque()
math::Vector3d AddedMassTorque ( math::Vector3d  lin_vel,
math::Matrix3d  m11,
math::Matrix3d  m12,
math::Matrix3d  m21,
math::Matrix3d  m22
[in]m21- The left lower [3x3] matrix of the added mass matrix
[in]m22- The right lower [3x3] matrix of the added mass matrix
The aerodynamic force.
EventManager &
◆ DynamicPressure()
double DynamicPressure ( math::Vector3d  vec,
double  air_density
[in]vec- The linear velocity
[in]air_density- The air density [kg/m^3]
The dynamic pressure, q
◆ LocalVelocity()
math::Vector3d LocalVelocity ( math::Vector3d  lin_vel,
math::Vector3d  dist
[in]lin_vel- The linear body velocity
[in]ang_vel- The angular body velocity
[in]dist- The distance vector from the origin
The local velocity at the distance vector
◆ SkewSymmetricMatrix()
math::Matrix3d SkewSymmetricMatrix ( math::Vector3d  mat)
[in]mat- A [3x1] vector
The skew-symmetric matrix of mat
