LogVideoRecorder Class Referencefinal
System which recordings videos from log playback There are two ways to specify what entities in the log playback to follow and record videos for: 1) by entity name and 2) by region. See the system parameters. More...
#include <gz/sim/systems/LogVideoRecorder.hh>
 LogVideoRecorder ()
 ~LogVideoRecorder () final=default
When recording is finished. An end string will be published to the /log_video_recorder/status topic and the videos are saved to a timestamped directory
  • <entity> Name of entity to record.
  • <region> Axis-aligned box where entities are at start of log
    • <min> Min corner position of box region.
    • <max> Max corner position of box region.
  • <start_time> Sim time when recording should start
  • <end_time> Sim time when recording should end
  • <exit_on_finish> Exit gz-sim when log playback recording ends
◆ LogVideoRecorder()
◆ ~LogVideoRecorder()
~LogVideoRecorder ( )
finaldefault
finalvirtual
◆ PostUpdate()
finalvirtual
