MecanumDrive Class Reference
Mecanum drive controller which can be attached to a model with any number of front/back left/right wheels. More...
#include <MecanumDrive.hh>
| MecanumDrive () | |
| Constructor. More... | |
| ~MecanumDrive () override=default | |
| Destructor. More... | |
| void | Configure (const Entity &_entity, const std::shared_ptr< const sdf::Element > &_sdf, EntityComponentManager &_ecm, EventManager &_eventMgr) override |
| void | PostUpdate (const UpdateInfo &_info, const EntityComponentManager &_ecm) override |
| void | PreUpdate (const UpdateInfo &_info, EntityComponentManager &_ecm) override |
| System ()=default | |
Public Types inherited from System | |
| using | PriorityType = int32_t |
| Signed integer type used for specifying priority of the execution order of PreUpdate and Update phases. More... | |
Static Public Attributes inherited from System | |
| constexpr static PriorityType | kDefaultPriority = {0} |
| Default priority value for execution order of the PreUpdate and Update phases. More... | |
| constexpr static std::string_view | kPriorityElementName |
| Name of the XML element from which the priority value will be parsed. More... | |
<front_left_joint>: Name of a joint that controls a front left wheel. This element can appear multiple times, and must appear at least once.<front_right_joint>: Name of a joint that controls a front right wheel. This element can appear multiple times, and must appear at least once.<back_left_joint>: Name of a joint that controls a back left wheel. This element can appear multiple times, and must appear at least once.<back_right_joint>: Name of a joint that controls a back right wheel. This element can appear multiple times, and must appear at least once.<wheelbase>: Longitudinal distance between front and back wheels, in meters. This element is optional, although it is recommended to be included with an appropriate value. The default value is 1.0m.<wheel_separation>: Lateral distance between left and right wheels, in meters. This element is optional, although it is recommended to be included with an appropriate value. The default value is 1.0m.<wheel_radius>: Wheel radius in meters. This element is optional, although it is recommended to be included with an appropriate value. The default value is 0.2m.<odom_publish_frequency>: Odometry publication frequency. This element is optional, and the default value is 50Hz.<topic>: Custom topic that this system will subscribe to in order to receive command velocity messages. This element if optional, and the default value is/model/{name_of_model}/cmd_vel.<odom_topic>: Custom topic on which this system will publish odometry messages. This element if optional, and the default value is/model/{name_of_model}/odometry.<tf_topic>: Custom topic on which this system will publish the transform fromframe_idtochild_frame_id. This element if optional, and the default value is/model/{name_of_model}/tf.<frame_id>: Customframe_idfield that this system will use as the origin of the odometry transform in both the<tf_topic>gz.msgs.Pose_Vmessage and the<odom_topic>gz.msgs.Odometrymessage. This element if optional, and the default value is{name_of_model}/odom.<child_frame_id>: Customchild_frame_idthat this system will use as the target of the odometry trasnform in both the<tf_topic>gz.msgs.Pose_Vmessage and the<odom_topic>gz.msgs.Odometrymessage. This element if optional, and the default value is{name_of_model}/{name_of_link}.<min_velocity>: Sets both the minimum linear and minimum angular velocity.<max_velocity>: Sets both the maximum linear and maximum angular velocity.<min_acceleration>: Sets both the minimum linear and minimum angular acceleration.<max_acceleration>: Sets both the maximum linear and maximum angular acceleration.<min_jerk>: Sets both the minimum linear and minimum angular jerk.<max_jerk>: Sets both the maximum linear and maximum angular jerk.<min_linear_velocity>: Sets the minimum linear velocity. Overrides<min_velocity>if set.<max_linear_velocity>: Sets the maximum linear velocity. Overrides<max_velocity>if set.<min_angular_velocity>: Sets the minimum angular velocity. Overrides<min_velocity>if set.<max_angular_velocity>: Sets the maximum angular velocity. Overrides<max_velocity>if set.<min_linear_acceleration>: Sets the minimum linear acceleration. Overrides<min_acceleration>if set.<max_linear_acceleration>: Sets the maximum linear acceleration. Overrides<max_acceleration>if set.<min_angular_acceleration>: Sets the minimum angular acceleration. Overrides<min_acceleration>if set.<max_angular_acceleration>: Sets the maximum angular acceleration. Overrides<max_acceleration>if set.<min_linear_jerk>: Sets the minimum linear jerk. Overrides<min_jerk>if set.<max_linear_jerk>: Sets the maximum linear jerk. Overrides<max_jerk>if set.<min_angular_jerk>: Sets the minimum angular jerk. Overrides<min_jerk>if set.<max_angular_jerk>: Sets the maximum angular jerk. Overrides<max_jerk>if set.
◆ MecanumDrive()
| MecanumDrive | ( | ) |
◆ ~MecanumDrive()
overridedefault |
◆ Configure()
overridevirtual |
◆ PostUpdate()
overridevirtual |
◆ PreUpdate()
overridevirtual |
