PerfectComms Class Reference
An example of a comms model. This model always delivers any message to its destination. More...
#include <PerfectComms.hh>
 PerfectComms ()
 ICommsModel ()
 Configure the system. More...
◆ PerfectComms()
PerfectComms ( )
◆ Load()
Implements ICommsModel.
◆ Step()
[in]_ecm- Gazebo Sim's ECM.
