Physics Class Reference
Base class for a System. More...
#include <gz/sim/systems/Physics.hh>
 Physics ()
 ~Physics () override
 Configure the system. More...
  • <include_entity_names>: Optional. When set to false, the name of colliding entities is not populated in the contacts. Remains true by default.
Example
filename="gz-sim-physics-system"
name="systems::Physics">
<contacts>
<include_entity_names>false</include_entity_names>
</contacts>
◆ Physics()
Physics ( )
◆ ~Physics()
~Physics ( )
finalvirtual
◆ Reset()
finalvirtual
Implements ISystemReset.
finalvirtual
Implements ISystemUpdate.
