Thermal Class Reference
A thermal plugin that sets the temperature for the parent entity. More...
#include <Thermal.hh>
 Thermal ()
 ~Thermal () override
◆ Thermal()
Thermal ( )
◆ ~Thermal()
~Thermal ( )
finalvirtual
