ThermalSensor Class Reference
A thermal sensor plugin for configuring thermal sensor properties. More...
#include <ThermalSensor.hh>
 ThermalSensor ()
 ~ThermalSensor () override
◆ ThermalSensor()
ThermalSensor ( )
◆ ~ThermalSensor()
~ThermalSensor ( )
finalvirtual
