VelocityControl Class Reference
Linear and angular velocity controller which is directly set on a model. More...
#include <VelocityControl.hh>
 VelocityControl ()
 ~VelocityControl () override=default
 Configure the system. More...
void PreUpdate (const UpdateInfo &, EntityComponentManager &_ecm) override
  • <topic>: Topic to receive commands in. Defaults to /model/<model_name>/cmd_vel.
  • <initial_linear>: Linear velocity to start with.
  • <initial_angular>: Linear velocity to start with.
◆ VelocityControl()
◆ ~VelocityControl()
~VelocityControl ( )
overridedefault
◆ PostUpdate()
void PreUpdate ( const UpdateInfo &  ,
