WheelSlip Class Reference
A system that updates wheel slip parameters based on linear wheel spin velocity (radius * spin rate). More...
#include <WheelSlip.hh>
 WheelSlip ()
 ~WheelSlip () override=default
 Configure the system. More...
System parameters
It currently assumes that the fdir1 friction parameter is set parallel to the joint axis (often [0 0 1]) and that the link origin is on the joint axis.
The slip parameter is a Force-Dependent Slip (slip1, slip2) and it has units of velocity / force (m / s / N), similar to the inverse of a viscous damping coefficient.
The slip_compliance parameters specified in this plugin are unitless, representing the lateral or longitudinal slip ratio (see https://en.wikipedia.org/wiki/Slip_(vehicle_dynamics) ) to tangential force ratio (tangential / normal force).
Note that the maximum force ratio is the friction coefficient. At each time step, these compliances are multiplied by the linear wheel spin velocity and divided by the wheel_normal_force parameter specified below in order to match the units of the slip parameters.
A graphical interpretation of these parameters is provided below for a positive value of slip compliance. The horizontal axis corresponds to the slip ratio at the wheel, and the vertical axis corresponds to the tangential force ratio (tangential / normal force).
As wheel slip increases, the tangential force increases until it reaches the maximum set by the friction coefficient. The slip compliance corresponds to the inverse of the slope of the force before it reaches the maximum value. A slip compliance of 0 corresponds to a completely vertical portion of the plot below. As slip compliance increases, the slope decreases.
| _________ friction coefficient .
| /-┘ slope is inverse of .
| / slip compliance .
--+-------------------------- slipRatio
Examples
<plugin filename="gz-sim-wheel-slip-system"
name="systems::WheelSlip">
<wheel link_name="wheel_front_left">
<slip_compliance_lateral>0</slip_compliance_lateral>
<slip_compliance_longitudinal>0.1</slip_compliance_longitudinal>
<wheel_normal_force>100</wheel_normal_force>
<wheel_radius>0.1651</wheel_radius>
</wheel>
<wheel link_name="wheel_front_right">
</wheel>
<wheel link_name="wheel_rear_left">
<wheel_normal_force>80</wheel_normal_force>
</wheel>
<wheel link_name="wheel_rear_right">
</wheel>
◆ WheelSlip()
WheelSlip ( )
◆ ~WheelSlip()
~WheelSlip ( )
overridedefault
