#include <EntityFeatureMap.hh>
Public Types | |
| template<typename T > | |
| using | HasFeatureList = std::disjunction< std::is_same< T, OptionalFeatureLists >... > |
| Checks whether type T is in the OptionalFeatureLists. More... | |
| using | PhysicsEntityPtr = physics::EntityPtr< PhysicsEntityT< PolicyT, T > > |
| Template that's preset with the class's Policy type. More... | |
| using | RequiredEntityPtr = PhysicsEntityPtr< RequiredFeatureList > |
| A EntityPtr with made from RequiredFeatureList. More... | |
| void | AddEntity (const Entity &_entity, const RequiredEntityPtr &_physicsEntity) |
| Add a mapping between gazebo and physics entities. More... | |
| template<typename ToFeatureList > | |
| PhysicsEntityPtr< ToFeatureList > | EntityCast (const RequiredEntityPtr &_physicsEntity) const |
| Helper function to cast from an entity type with minimum features to an entity with a different set of features. This overload takes a physics entity as input. More... | |
| PhysicsEntityPtr< ToFeatureList > | EntityCast (sim::Entity _entity) const |
| Helper function to cast from an entity type with minimum features to an entity with a different set of features. When the entity is cast successfully, it is added to an internal cache so that subsequent casts will use the entity from the cache. More... | |
| RequiredEntityPtr | Get (const Entity &_entity) const |
| Get the physics entity with required features that corresponds to the input Gazebo entity. More... | |
| Entity | Get (const RequiredEntityPtr &_physEntity) const |
| Get Gazebo entity that corresponds to the physics entity with required features. More... | |
| Entity | GetByPhysicsId (std::size_t _id) const |
| Get Gazebo entity that corresponds to the physics entity ID. More... | |
| RequiredEntityPtr | GetPhysicsEntityPtr (std::size_t _id) const |
| Get the physics entity with required features that has a particular ID. More... | |
| bool | HasEntity (const Entity &_entity) const |
| Check whether there is a physics entity associated with the given Gazebo entity. More... | |
| bool | HasEntity (const RequiredEntityPtr &_physicsEntity) const |
| Check whether there is a gazebo entity associated with the given physics entity. More... | |
| const std::unordered_map< Entity, RequiredEntityPtr > & | Map () const |
| Get the map from Gazebo entity to physics entities with required features. More... | |
| bool | Remove (const RequiredEntityPtr &_physicsEntity) |
| Remove physics entity from all associated maps. More... | |
| bool | Remove (Entity _entity) |
| Remove entity from all associated maps. More... | |
| std::size_t | TotalMapEntryCount () const |
| Get the total number of entries in the maps. Only used for testing. More... | |
Member Typedef Documentation
◆ HasFeatureList
| using HasFeatureList = std::disjunction<std::is_same<T, OptionalFeatureLists>...> |
- Template Parameters
T A FeatureList to search for in OptionalFeatureLists
◆ PhysicsEntityPtr
| using PhysicsEntityPtr = physics::EntityPtr<PhysicsEntityT<PolicyT, T> > |
T A FeatureList that is used in creating an EntityPtr
◆ RequiredEntityPtr
| using RequiredEntityPtr = PhysicsEntityPtr<RequiredFeatureList> |
◆ AddEntity()
inline |
[in] _entity Gazebo entity. [in] _physicsEntity Physics entity with required feature
◆ EntityCast() [1/2]
inline |
ToFeatureList The list of features of the resulting entity.
[in] _physicsEntity Physics entity with required features.
- Returns
- Physics entity with features in ToFeatureList. nullptr if the entity can't be found or the physics engine doesn't support the requested feature.
References EntityFeatureMap< PhysicsEntityT, PolicyT, RequiredFeatureList, OptionalFeatureLists >::Get(), and gz::sim::kNullEntity.
◆ EntityCast() [2/2]
inline |
- Returns
References unordered_map< K, T >::end(), unordered_map< K, T >::find(), and EntityFeatureMap< PhysicsEntityT, PolicyT, RequiredFeatureList, OptionalFeatureLists >::Get().
◆ Get() [1/2]
inline |
- Returns
- If found, returns the corresponding physics entity. Otherwise, nullptr
References unordered_map< K, T >::end(), and unordered_map< K, T >::find().
Referenced by EntityFeatureMap< PhysicsEntityT, PolicyT, RequiredFeatureList, OptionalFeatureLists >::EntityCast().
◆ Get() [2/2]
inline |
[in] _physEntity Physics entity with required features
- Returns
- If found, returns the corresponding Gazebo entity. Otherwise, kNullEntity
References unordered_map< K, T >::end(), unordered_map< K, T >::find(), and gz::sim::kNullEntity.
◆ GetByPhysicsId()
inline |
[in] _id Physics entity ID
- Returns
◆ GetPhysicsEntityPtr()
inline |
[in] _id The ID of the desired physics entity
- Returns
◆ HasEntity() [1/2]
inline |
- Returns
- True if the there is a physics entity associated with the given Gazebo entity
◆ HasEntity() [2/2]
inline |
[in] _physicsEntity physics entity with required features.
- Returns
- True if the there is a gazebo entity associated with the given physics entity
◆ Map()
inline |
- Returns
- Immumtable entity map
◆ Remove() [1/2]
inline |
[in] _physicsEntity Physics entity.
- Returns
- True if the entity was found and removed.
References unordered_map< K, T >::end(), unordered_map< K, T >::erase(), and unordered_map< K, T >::find().
◆ Remove() [2/2]
inline |
- Returns
◆ TotalMapEntryCount()
inline |
- Returns
- Number of entries in all the maps.
References unordered_map< K, T >::size().
