gz::sim::logical_audio Namespace Reference
struct  Microphone
 Properties of a logical audio microphone. A microphone also has a pose, which can be stored as a component of a microphone entity via components::Pose. More...
struct  Source
 Properties of a logical audio source. A source also has a pose, which can be stored as a component of a source entity via components::Pose. More...
struct  SourcePlayInfo
 A source's playing information. Useful for keeping track of when to start/stop playing a source. More...
Enumerations
enum class  AttenuationFunction { LINEAR , UNDEFINED }
 Audio source attenuation functions. AttenuationFunction::Undefined is used to indicate that an attenuation function has not been defined yet. More...
enum class  AttenuationShape { SPHERE , UNDEFINED }
 Audio source attenuation shapes. AttenuationShape::Undefined is used to indicate that an attenuation shape has not been defined yet. More...
Functions
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE double computeVolume (bool _playing, AttenuationFunction _attenuationFunc, AttenuationShape _attenuationShape, double _sourceEmissionVolume, double _innerRadius, double _falloffDistance, const gz::math::Pose3d &_sourcePose, const gz::math::Pose3d &_targetPose)
 Computes the volume level of an audio source at a certain location. More...
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE bool detect (double _volumeLevel, double _volumeDetectionThreshold)
 Determines if an audio device can detect volume at a certain level. More...
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE void setAttenuationFunction (AttenuationFunction &_attenuationFunc, std::string _str)
 Set the attenuation function that matches the defined string. The string is not case sensitive, and must match the spelling of the values in AttenuationFunction. If the spelling does not match, the attenuation function is set as AttenuationFunction::Undefined. More...
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE void setAttenuationShape (AttenuationShape &_attenuationShape, std::string _str)
 Set the attenuation shape that matches the defined string. The string is not case sensitive, and must match the spelling of the values in AttenuationShape. If the spelling does not match, the attenuation shape is set as AttenuationShape::Undefined. More...
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE void validateInnerRadiusAndFalloffDistance (double &_innerRadius, double &_falloffDistance)
 Validate the inner radius and falloff distance for an audio source. More...
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE void validateVolumeLevel (double &_volumeLevel)
 Validate a source's emission volume level. More...
◆ AttenuationFunction
enum AttenuationFunction
strong
Enumerator
LINEAR
UNDEFINED
◆ AttenuationShape
enum AttenuationShape
strong
Enumerator
SPHERE
UNDEFINED
Function Documentation
◆ computeVolume()
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE double gz::sim::logical_audio::computeVolume ( bool  _playing,
const gz::math::Pose3d &  _sourcePose,
const gz::math::Pose3d &  _targetPose
Note
Users should call logical_audio::ValidateInnerRadiusAndFalloffDistance and logical_audio::ValidateVolumeLevel before calling this method in order to prevent undefined behavior.
[in]_playingWhether the audio source is playing or not.
[in]_attenuationFuncThe source's attenuation function.
[in]_attenuationShapeThe source's attenuation shape.
[in]_sourceEmissionVolumeThe source's emission volume level.
[in]_innerRadiusThe source's inner radius, which should be >= 0.
[in]_falloffDistanceThe source's falloffDistance, which should be greater than _innerRadius.
[in]_sourcePoseThe source's pose.
[in]_targetPoseThe pose where the volume level should be calculated.
The volume level at this location. If the attenuation function or shape is undefined, -1.0 is returned. If the source is not playing, 0.0 is returned.
◆ detect()
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE bool gz::sim::logical_audio::detect ( double  _volumeLevel,
[in]_volumeLevelThe volume level that the microphone is attempting to detect. This should be a value between 0.0 (no volume) and 1.0 (maximum volume).
[in]_volumeDetectionThresholdThe listening device's minimum audio detection volume. This should be a value between 0.0 and 1.0. A device with a low detection threshold can hear a wider range of audio than a device with a higher detection threshold.
true if the listening device can detect volume at _volumeLevel, false otherwise.
◆ setAttenuationFunction()
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE void gz::sim::logical_audio::setAttenuationFunction ( AttenuationFunction &  _attenuationFunc,
std::string  _str
Example: to set the attenuation function to AttenuationFunction::Linear, the following are examples of valid strings: "linear", "Linear", "LINEAR"
[out]_attenuationFuncA reference to the variable that stores the calculated attenuation function.
[in]_strA string that should map to a value in AttenuationFunction.
◆ setAttenuationShape()
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE void gz::sim::logical_audio::setAttenuationShape ( AttenuationShape &  _attenuationShape,
std::string  _str
Example: to set the attenuation shape to AttenuationShape::Sphere, the following are examples of valid strings: "sphere", "Sphere", "SPHERE"
[out]_attenuationShapeA reference to the variable that stores the calculated attenuation shape.
[in]_strA string that should map to a value in AttenuationShape.
◆ validateInnerRadiusAndFalloffDistance()
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE void gz::sim::logical_audio::validateInnerRadiusAndFalloffDistance ( double &  _innerRadius,
double &  _falloffDistance
[in,out]_innerRadiusThe inner radius to set for the source. This value must be > 0. If the value of this parameter is < 0, the source's inner radius will be set to 0.
[in,out]_falloffDistanceThe falloff distance to set for the source. This value must be greater than _innerRadius. If _falloffDistance < _innerRadius, _falloffDistance will be set to _innerRadius + 1 (assuming that _innerRadius is valid).
◆ validateVolumeLevel()
GZ_SIM_LOGICALAUDIOSENSORPLUGIN_SYSTEM_VISIBLE void gz::sim::logical_audio::validateVolumeLevel ( double &  _volumeLevel)
[in,out]_volumeLevelThe volume the source should play at. This parameter is checked (and possibly clipped) to ensure that it falls between 0.0 (0% volume) and 1.0 (100% volume).
