BaseGaussianNoisePass< T > Class Template Reference
Base Gaussian noise render pass. More...
#include <BaseGaussianNoisePass.hh>
 ~BaseGaussianNoisePass () override
double Bias () const override
 Accessor for bias.
double Mean () const override
 Accessor for mean.
void SetBiasMean (double _biasMean) override
 Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation.
void SetBiasStdDev (double _biasStdDev) override
 Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation.
void SetMean (double _mean) override
 Set mean.
void SetStdDev (double _stdDev) override
 Set stddev.
double StdDev () const override
 Accessor for stddev.
- Public Member Functions inherited from GaussianNoisePass
virtual ~GaussianNoisePass ()
virtual ~RenderPass ()
virtual void SetWideAngleCameraAfterStitching (bool _afterStitching)=0
virtual bool WideAngleCameraAfterStitching () const =0
void SampleBias ()
double bias = 0.0
 Gaussian noise bias.
double biasMean = 0
 The mean of the Gaussian distribution from which bias values are drawn.
double biasStdDev = 0
 The standard deviation of the Gaussian distribution from which bias values are drawn.
double mean = 0.0
 Gaussian noise mean.
double stdDev = 0.0
 Standard deviation of Gaussian noise.
template<class T>
class gz::rendering::BaseGaussianNoisePass< T >
◆ BaseGaussianNoisePass()
template<class T >
BaseGaussianNoisePass ( )
◆ ~BaseGaussianNoisePass()
template<class T >
~BaseGaussianNoisePass ( )
◆ Bias()
template<class T >
double Bias ( ) const
Accessor for bias.
Bias on output.
Implements GaussianNoisePass.
◆ Mean()
template<class T >
double Mean ( ) const
Accessor for mean.
Mean of Gaussian noise.
◆ SampleBias()
template<class T >
void SampleBias ( )
◆ SetBiasMean()
template<class T >
void SetBiasMean ( double  _biasMean)
SetBiasStdDev
◆ SetBiasStdDev()
template<class T >
void SetBiasStdDev ( double  _biasStdDev)
SetBiasMean
◆ SetMean()
template<class T >
void SetMean ( double  _mean)
Set mean.
[in]_meanMean of Gaussian noise.
◆ SetStdDev()
template<class T >
void SetStdDev ( double  _stdDev)
Set stddev.
[in]_stdDevStandard deviation of Gaussian noise.
◆ StdDev()
template<class T >
double StdDev ( ) const
◆ bias
template<class T >
double bias = 0.0
◆ biasMean
template<class T >
double biasMean = 0
◆ biasStdDev
template<class T >
◆ mean
template<class T >
double mean = 0.0
◆ stdDev
template<class T >
double stdDev = 0.0
