WideAngleCamera Class Referenceabstract
Wide angle camera class. More...
#include <WideAngleCamera.hh>
virtual ~WideAngleCamera ()
virtual common::ConnectionPtr ConnectNewWideAngleFrame (std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0
virtual const CameraLens & Lens () const =0
 Get the camera lens used by this wide angle camera.
virtual math::Vector3d Project3d (const math::Vector3d &_pt) const =0
 Project 3D world coordinates to screen coordinates.
virtual void SetLens (const CameraLens &_lens)=0
 Set the camera lens to use for this wide angle camera.
virtual ~Camera ()
 Create a render window.
virtual void PrepareForExternalSampling ()=0
virtual void Render ()=0
 Get a render passes by index.
virtual void RenderTextureMetalId (void *_textureIdPtr) const =0
virtual void SetImageFormat (PixelFormat _format, bool _reinterpretable=false)=0
 Set the image pixel format.
virtual void Update ()=0
virtual VisualPtr VisualAt (const gz::math::Vector2i &_mousePos)=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
gz/rendering/WideAngleCamera.hh
◆ ~WideAngleCamera()
virtual ~WideAngleCamera ( )
◆ ConnectNewWideAngleFrame()
virtual common::ConnectionPtr ConnectNewWideAngleFrame ( std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberNew camera listener callback
Implemented in BaseWideAngleCamera< T >, BaseWideAngleCamera< Ogre2Sensor >, BaseWideAngleCamera< OgreSensor >, OgreWideAngleCamera, and Ogre2WideAngleCamera.
◆ Lens()
virtual const CameraLens & Lens ( ) const
Camera lens set to this wide angle camera
Implemented in BaseWideAngleCamera< T >, BaseWideAngleCamera< Ogre2Sensor >, and BaseWideAngleCamera< OgreSensor >.
◆ Project3d()
virtual math::Vector3d Project3d ( const math::Vector3d &  _pt) const
[in]_pt3D world coordinates
Screen coordinates. Z is the distance of point from camera optical center.
◆ SetLens()
virtual void SetLens ( const CameraLens &  _lens)
[in]_lensCamera lens to set
