BaseWideAngleCamera< T > Class Template Reference
#include <BaseWideAngleCamera.hh>
virtual ~BaseWideAngleCamera ()
virtual common::ConnectionPtr ConnectNewWideAngleFrame (std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
virtual void CreateWideAngleTexture ()
virtual const CameraLens & Lens () const override
 Get the camera lens used by this wide angle camera.
virtual math::Vector3d Project3d (const math::Vector3d &_pt) const override
 Project 3D world coordinates to screen coordinates.
virtual void SetLens (const CameraLens &_lens) override
 Set the camera lens to use for this wide angle camera.
- Public Member Functions inherited from WideAngleCamera
virtual ~WideAngleCamera ()
virtual ~Camera ()
virtual void Render ()=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
virtual ~BaseCamera ()
 Create a render window.
 Get a render passes by index.
 Set the image pixel format.
 BaseCamera ()
CameraLens lens
 Camera lens used by this wide angle camera.
 Anti-aliasing.
double aspect = 1.3333333
 Aspect ratio.
double farClip = 1000.0
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
◆ BaseWideAngleCamera()
template<class T >
BaseWideAngleCamera ( )
◆ ~BaseWideAngleCamera()
template<class T >
~BaseWideAngleCamera ( )
◆ ConnectNewWideAngleFrame()
template<class T >
common::ConnectionPtr ConnectNewWideAngleFrame ( std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberNew camera listener callback
Implements WideAngleCamera.
Reimplemented in OgreWideAngleCamera, and Ogre2WideAngleCamera.
◆ CreateWideAngleTexture()
template<class T >
void CreateWideAngleTexture ( )
◆ Lens()
template<class T >
const CameraLens & Lens ( ) const
Camera lens set to this wide angle camera
◆ Project3d()
template<class T >
math::Vector3d Project3d ( const math::Vector3d &  _pt) const
[in]_pt3D world coordinates
Screen coordinates. Z is the distance of point from camera optical center.
References std::endl(), Scene::Engine(), gzerr, and RenderEngine::Name().
◆ SetLens()
template<class T >
void SetLens ( const CameraLens &  _lens)
[in]_lensCamera lens to set
◆ lens
template<class T >
CameraLens lens
