RenderPass Class Referenceabstract
#include <gz/rendering/RenderPass.hh>
virtual ~RenderPass ()
virtual void SetWideAngleCameraAfterStitching (bool _afterStitching)=0
virtual bool WideAngleCameraAfterStitching () const =0
◆ ~RenderPass()
virtual ~RenderPass ( )
◆ IsEnabled()
True if the render pass is enabled, false otherwise.
Implemented in BaseRenderPass< T >, BaseRenderPass< Ogre2Object >, and BaseRenderPass< OgreObject >.
virtual void PreRender ( const CameraPtr &  _camera)
Implemented in BaseRenderPass< T >, BaseRenderPass< Ogre2Object >, BaseRenderPass< OgreObject >, OgreLensFlarePass, Ogre2GaussianNoisePass, and Ogre2LensFlarePass.
◆ SetEnabled()
[in]_enabledTrue to enable the render pass, false to disable.
◆ SetWideAngleCameraAfterStitching()
virtual void SetWideAngleCameraAfterStitching ( bool  _afterStitching)
This function controls whether the effect is applied to each 6 faces individually; or during the "stitching" pass.
The default setting depends on the RenderPass (e.g. LensFlare defaults to true)
Remarks
This setting must not be changed after adding the RenderPass to a Camera.
[in]_afterStitchingTrue if it should be done after stitching, False if it should be done to each of the 6 faces separately.
◆ WideAngleCameraAfterStitching()
virtual bool WideAngleCameraAfterStitching ( ) const
The current value set by SetWideAngleCameraAfterStitching
