BaseNodeCompositeStore Class Reference
#include <BaseStorage.hh>
- Public Member Functions inherited from BaseCompositeStore< Node >
 BaseCompositeStore ()
virtual ~BaseCompositeStore ()
 Add given element. If the element has already been added or its name or ID conflict with other existing elements, then no work will be done.
virtual bool AddStore (TStorePtr _store)
 Add the given store. If the given store already exists, then no work will be done.
virtual bool ContainsStore (ConstTStorePtr _store) const
 Determine if given store exists.
 Remove and destroy given element. If the given element does not exists, in this store, then no work will be done.
virtual void DestroyAll ()
 Remove and destroy element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual TStorePtr GetStore (unsigned int _index) const
 Get store at the given index. If no such store exists NULL will be returned.
virtual unsigned int GetStoreCount () const
 Get number of Stores.
virtual void RemoveAll ()
 Remove element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual TStorePtr RemoveStore (TStorePtr _store)
 Remove given store. If no such store exists no work will be done and NULL will be returned.
virtual TStorePtr RemoveStore (unsigned int _index)
 Remove store at the given index. If no such store exists no work will be done and NULL will be returned.
virtual TStorePtr RemoveStoreImpl (TStoreIter _iter)
- Public Member Functions inherited from CompositeStore< T >
virtual ~CompositeStore ()=default
virtual ~Store ()=default
- Protected Attributes inherited from BaseCompositeStore< Node >
TStoreList stores
