Ogre2.x implementation of the submesh class. More...
#include <Ogre2Mesh.hh>
virtual ~Ogre2SubMesh ()
virtual Ogre::SubItem * Ogre2SubItem () const
 Get internal ogre subitem created from this submesh.
void SetMeshName (const std::string &_name)
 Set the name of the mesh stored in Ogre2.
- Public Member Functions inherited from BaseSubMesh< Ogre2Object >
virtual ~BaseSubMesh ()
 Get the currently assigned material.
 Set the materials of this SubMesh. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done.
- Public Member Functions inherited from SubMesh
virtual ~SubMesh ()
 Ogre2SubMesh ()
 Initialize the submesh.
virtual void SetMaterialImpl (MaterialPtr _material) override
 Helper function for setting the material to use.
- Protected Member Functions inherited from BaseSubMesh< Ogre2Object >
 BaseSubMesh ()
Ogre::SubItem * ogreSubItem = nullptr
 Ogre subitem representing the submesh.
- Protected Attributes inherited from BaseSubMesh< Ogre2Object >
 Pointer to currently assigned material.
bool ownsMaterial
 Flag to indicate whether or not this submesh should be responsible for destroying the material.
 Pointer to the ogre scene.
◆ Ogre2SubMesh()
Ogre2SubMesh ( )
◆ ~Ogre2SubMesh()
virtual ~Ogre2SubMesh ( )
Reimplemented from BaseSubMesh< Ogre2Object >.
◆ Ogre2SubItem()
virtual Ogre::SubItem * Ogre2SubItem ( ) const
◆ SetMaterialImpl()
virtual void SetMaterialImpl ( MaterialPtr  _material)
[in]_materialMaterial to be assigned to the submesh
Implements BaseSubMesh< Ogre2Object >.
◆ SetMeshName()
void SetMeshName ( const std::string &  _name)
[in]_nameName of the mesh
◆ ogreSubItem
Ogre::SubItem* ogreSubItem = nullptr
