BaseSubMesh< T > Class Template Referenceabstract
#include <BaseMesh.hh>
virtual ~BaseSubMesh ()
 Get the currently assigned material.
 Set the materials of this SubMesh. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done.
virtual void SetMaterialImpl (MaterialPtr _material)=0
 Engine implementation for setting the material of this SubMesh.
- Public Member Functions inherited from SubMesh
virtual ~SubMesh ()
 BaseSubMesh ()
 Pointer to currently assigned material.
bool ownsMaterial = false
 Flag to indicate whether or not this submesh should be responsible for destroying the material.
◆ BaseSubMesh()
template<class T >
BaseSubMesh ( )
◆ ~BaseSubMesh()
template<class T >
~BaseSubMesh ( )
template<class T >
void Destroy ( )
Reimplemented in OgreSubMesh, and Ogre2SubMesh.
References Scene::DestroyMaterial().
template<class T >
The currently assigned material
Implements SubMesh.
template<class T >
void PreRender ( )
References Object::PreRender().
◆ SetMaterial() [1/2]
template<class T >
bool  _unique = true
Implements SubMesh.
References Scene::Material().
◆ SetMaterial() [2/2]
template<class T >
bool  _unique = true
Implements SubMesh.
◆ SetMaterialImpl()
template<class T >
virtual void SetMaterialImpl ( MaterialPtr  _material)
Implemented in OgreSubMesh, and Ogre2SubMesh.
◆ material
template<class T >
◆ ownsMaterial
template<class T >
