#include <OgreMesh.hh>
virtual ~OgreSubMesh ()
virtual Ogre::SubEntity * OgreSubEntity () const
- Public Member Functions inherited from BaseSubMesh< OgreObject >
virtual ~BaseSubMesh ()
 Get the currently assigned material.
 Set the materials of this SubMesh. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done.
- Public Member Functions inherited from SubMesh
virtual ~SubMesh ()
 OgreSubMesh ()
virtual void SetMaterialImpl (MaterialPtr _material) override
 Engine implementation for setting the material of this SubMesh.
- Protected Member Functions inherited from BaseSubMesh< OgreObject >
 BaseSubMesh ()
Ogre::SubEntity * ogreSubEntity
- Protected Attributes inherited from BaseSubMesh< OgreObject >
 Pointer to currently assigned material.
bool ownsMaterial
 Flag to indicate whether or not this submesh should be responsible for destroying the material.
◆ OgreSubMesh()
OgreSubMesh ( )
◆ ~OgreSubMesh()
virtual ~OgreSubMesh ( )
Reimplemented from BaseSubMesh< OgreObject >.
◆ OgreSubEntity()
virtual Ogre::SubEntity * OgreSubEntity ( ) const
◆ SetMaterialImpl()
virtual void SetMaterialImpl ( MaterialPtr  _material)
Implements BaseSubMesh< OgreObject >.
◆ ogreSubEntity
Ogre::SubEntity* ogreSubEntity
