#include <OgreRayQuery.hh>
virtual ~OgreRayQuery () override
virtual RayQueryResult ClosestPoint (bool _forceSceneUpdate=true) override
 Compute intersections.
virtual void SetFromCamera (const CameraPtr &_camera, const math::Vector2d &_coord) override
 Create the ray query from camera.
void SetFromCamera (const WideAngleCameraPtr &_camera, uint32_t _faceIdx, const math::Vector2d &_coord) override
 Create the ray query from WideAngleCamera.
- Public Member Functions inherited from BaseRayQuery< OgreObject >
 Get ray direction.
 Get ray origin.
 Set ray direction.
 Set ray origin.
void SetPreferGpu (bool _preferGpu) override
 If possible & supported (and user called SetFromCamera()) will use the GPU to perform the ray query. Triangle-level accurate.
bool UsesGpu () const override
 Returns true if the GPU will be used for the next ClosestPoint() call.
virtual ~RayQuery ()
 OgreRayQuery ()
- Protected Member Functions inherited from BaseRayQuery< OgreObject >
 BaseRayQuery ()
virtual void Init ()
- Protected Attributes inherited from BaseRayQuery< OgreObject >
math::Vector3d direction
 Ray direction.
 Ray origin.
gz/rendering/base/OgreRayQuery.hh
◆ OgreRayQuery()
OgreRayQuery ( )
◆ ~OgreRayQuery()
virtual ~OgreRayQuery ( )
◆ ClosestPoint()
virtual RayQueryResult ClosestPoint ( bool  _forceSceneUpdate = true)
[in]_forceSceneUpdatePerformance optimization hint When true Ogre2 will update all derived transforms to their latest to get correct results.
When false, that step is skipped. It is only safe to set it to false when nothing has changed since the last update (i.e. nothing moved, no new objects created).
Ogre will assert if built in Debug mode if this value is set to false when it shouldn't be.
See https://ogrecave.github.io/ogre-next/api/2.2/ _ogre20_changes.html::AssersionCachedOutOfDate for more info
Reimplemented from BaseRayQuery< OgreObject >.
◆ SetFromCamera() [1/2]
◆ SetFromCamera() [2/2]
void SetFromCamera ( const WideAngleCameraPtr &  _camera,
uint32_t  _faceIdx,
[in]_faceIdxIn range [0; 6)
  • 0 = +X
  • 1 = -X
  • 2 = +Y
  • 3 = -Y
  • 4 = +Z
  • 5 = -Z
Implements RayQuery.
