#include <BaseRayQuery.hh>
virtual RayQueryResult ClosestPoint (bool _forceSceneUpdate=true) override
 Compute intersections.
 Get ray direction.
 Get ray origin.
 Set ray direction.
virtual void SetFromCamera (const CameraPtr &_camera, const math::Vector2d &_coord) override
 Create the ray query from camera.
 Set ray origin.
void SetPreferGpu (bool _preferGpu) override
 If possible & supported (and user called SetFromCamera()) will use the GPU to perform the ray query. Triangle-level accurate.
bool UsesGpu () const override
 Returns true if the GPU will be used for the next ClosestPoint() call.
virtual ~RayQuery ()
virtual void SetFromCamera (const WideAngleCameraPtr &_camera, uint32_t _faceIdx, const math::Vector2d &_coord)=0
 Create the ray query from WideAngleCamera.
 BaseRayQuery ()
math::Vector3d direction
 Ray direction.
 Ray origin.
template<class T>
class gz::rendering::BaseRayQuery< T >
gz/rendering/base/BaseRayQuery.hh
◆ BaseRayQuery()
template<class T >
BaseRayQuery ( )
◆ ~BaseRayQuery()
template<class T >
~BaseRayQuery ( )
◆ ClosestPoint()
template<class T >
RayQueryResult ClosestPoint ( bool  _forceSceneUpdate = true)
[in]_forceSceneUpdatePerformance optimization hint When true Ogre2 will update all derived transforms to their latest to get correct results.
When false, that step is skipped. It is only safe to set it to false when nothing has changed since the last update (i.e. nothing moved, no new objects created).
Ogre will assert if built in Debug mode if this value is set to false when it shouldn't be.
See https://ogrecave.github.io/ogre-next/api/2.2/ _ogre20_changes.html::AssersionCachedOutOfDate for more info
Implements RayQuery.
Reimplemented in OgreRayQuery, and Ogre2RayQuery.
References RayQueryResult::distance.
◆ Direction()
template<class T >
gz::math::Vector3d Direction ( ) const
Get ray direction.
Ray direction.
◆ Origin()
template<class T >
gz::math::Vector3d Origin ( ) const
Get ray origin.
Ray origin
◆ SetDirection()
template<class T >
Set ray direction.
[in]_dirRay origin
◆ SetFromCamera()
template<class T >
void SetFromCamera ( const CameraPtr &  _camera,
References Vector2< typename T >::X(), and Vector2< typename T >::Y().
◆ SetOrigin()
template<class T >
void SetOrigin ( const math::Vector3d &  _origin)
Set ray origin.
[in]_originRay origin
◆ SetPreferGpu()
template<class T >
void SetPreferGpu ( bool  _preferGpu)
Remarks
It's not guaranteed the GPU will be used. See UsesGpu()
Using the GPU is not necessarily faster.
[in]_preferGpuTrue to use the GPU if available & possible. False to never use the GPU.
Reimplemented in Ogre2RayQuery.
◆ UsesGpu()
template<class T >
bool UsesGpu ( ) const
Remarks
The thread ID is important. Calling this value from different threads may result in different return values.
True if next ClosestPoint() call will use the GPU.
◆ direction
template<class T >
Ray direction.
◆ origin
template<class T >
Ray origin.
