RenderTexture Class Referenceabstract
Represents a off-screen render-texture to which cameras can render images. More...
#include <RenderTarget.hh>
virtual ~RenderTexture ()
virtual unsigned int GLId () const =0
 Returns the OpenGL texture Id. A valid Id is returned only.
virtual void MetalId (void *_textureIdPtr) const =0
 Gets the Metal texture id. A valid Id is obtained only if this is an Metal render texture. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease.
virtual ~RenderTarget ()
 Write rendered image to given Image. The RenderTarget will convert the underlying image to the specified format listed in the given Image. However if the given image is not of the correct size no work will be done. Calling this function before an image has been rendered will result in undefined behavior.
virtual bool Reinterpretable () const =0
 See SetFormat()
 Remove all render passes from the render target.
 Get a render pass by index.
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false)=0
◆ ~RenderTexture()
virtual ~RenderTexture ( )
◆ GLId()
virtual unsigned int GLId ( ) const
Implemented in BaseRenderTexture< T >, BaseRenderTexture< Ogre2RenderTarget >, BaseRenderTexture< OgreRenderTarget >, OgreRenderTexture, and Ogre2RenderTexture.
◆ MetalId()
virtual void MetalId ( void *  _textureIdPtr) const
Implemented in BaseRenderTexture< T >, BaseRenderTexture< Ogre2RenderTarget >, BaseRenderTexture< OgreRenderTarget >, and Ogre2RenderTexture.
