BaseRenderTexture< T > Class Template Reference
 BaseRenderTexture ()
 ~BaseRenderTexture () override
virtual unsigned int GLId () const override
 Returns the OpenGL texture Id. A valid Id is returned only.
virtual void MetalId (void *_textureIdPtr) const override
 Gets the Metal texture id. A valid Id is obtained only if this is an Metal render texture. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease.
virtual ~RenderTexture ()
virtual ~RenderTarget ()
 Write rendered image to given Image. The RenderTarget will convert the underlying image to the specified format listed in the given Image. However if the given image is not of the correct size no work will be done. Calling this function before an image has been rendered will result in undefined behavior.
virtual bool Reinterpretable () const =0
 See SetFormat()
 Remove all render passes from the render target.
 Get a render pass by index.
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false)=0
◆ BaseRenderTexture()
template<class T >
BaseRenderTexture ( )
◆ ~BaseRenderTexture()
template<class T >
~BaseRenderTexture ( )
◆ GLId()
template<class T >
unsigned int GLId ( ) const
Implements RenderTexture.
Reimplemented in OgreRenderTexture, and Ogre2RenderTexture.
◆ MetalId()
template<class T >
void MetalId ( void *  _textureIdPtr) const
Reimplemented in Ogre2RenderTexture.
