BaseGaussianNoisePass< T > Class Template Reference
Base Gaussian noise render pass. More...
#include <BaseGaussianNoisePass.hh>
virtual | ~BaseGaussianNoisePass () |
Destructor. More... | |
double | Bias () const |
Accessor for bias. More... | |
double | Mean () const |
Accessor for mean. More... | |
void | SetBiasMean (double _biasMean) |
Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
void | SetBiasStdDev (double _biasStdDev) |
Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
void | SetMean (double _mean) |
Set mean. More... | |
void | SetStdDev (double _stdDev) |
Set stddev. More... | |
double | StdDev () const |
Accessor for stddev. More... | |
Public Member Functions inherited from GaussianNoisePass | |
GaussianNoisePass () | |
Constructor. More... | |
virtual | ~GaussianNoisePass () |
Public Member Functions inherited from RenderPass | |
virtual | ~RenderPass () |
virtual bool | IsEnabled () const =0 |
Get whether or not the render pass is enabled. More... | |
virtual void | SetEnabled (bool _enabled)=0 |
Set to enable or disable the render pass. More... | |
virtual | ~Object () |
virtual void | Destroy ()=0 |
BaseGaussianNoisePass () | |
void | SampleBias () |
Protected Attributes | |
double | bias = 0.0 |
Gaussian noise bias. More... | |
double | biasMean = 0 |
The mean of the Gaussian distribution from which bias values are drawn. More... | |
double | biasStdDev = 0 |
The standard deviation of the Gaussian distribution from which bias values are drawn. More... | |
double | mean = 0.0 |
Gaussian noise mean. More... | |
double | stdDev = 0.0 |
Standard deviation of Gaussian noise. More... | |
template<class T>
class ignition::rendering::BaseGaussianNoisePass< T >
◆ BaseGaussianNoisePass()
protected |
◆ ~BaseGaussianNoisePass()
virtual |
◆ Bias()
virtual |
◆ Mean()
virtual |
◆ SampleBias()
protected |
◆ SetBiasMean()
virtual |
- See also
- SetBiasStdDev
Implements GaussianNoisePass.
◆ SetBiasStdDev()
virtual |
- See also
- SetBiasMean
◆ SetMean()
virtual |
◆ SetStdDev()
virtual |
Set stddev.
[in] _stdDev Standard deviation of Gaussian noise.
◆ StdDev()
virtual |
◆ bias
protected |
◆ biasMean
protected |
◆ biasStdDev
protected |
◆ mean
protected |
◆ stdDev
protected |
