gz/rendering/RenderTarget.hh
STL class.
virtual unsigned int RenderPassCount() const =0
Represents a off-screen render-texture to which cameras can render images.
Definition: gz/rendering/RenderTarget.hh:103
PixelFormat
Image pixel format types.
Definition: gz/rendering/PixelFormat.hh:32
virtual void AddRenderPass(const RenderPassPtr &_pass)=0
virtual void SetDevicePixelRatio(const double _ratio)=0
Set the device to pixel ratio.
Represents a on-screen render-window to which cameras can render images.
Definition: gz/rendering/RenderTarget.hh:119
Definition: gz/rendering/Image.hh:36
virtual ~RenderWindow()
Deconstructor.
Definition: gz/rendering/RenderTarget.hh:123
virtual unsigned int Width() const =0
virtual unsigned int Height() const =0
virtual void Copy(Image &_image) const =0
Write rendered image to given Image. The RenderTarget will convert the underlying image to the specif...
virtual std::string Handle() const =0
Get the window handle that the render window is attached to.
virtual ~RenderTarget()
Definition: gz/rendering/RenderTarget.hh:41
virtual ~RenderTexture()
Deconstructor.
Definition: gz/rendering/RenderTarget.hh:107
virtual math::Color BackgroundColor() const =0
virtual RenderPassPtr RenderPassByIndex(unsigned int _index) const =0
Get a render pass by index.
Definition: gz/rendering/RenderTarget.hh:37
virtual void OnResize(unsigned int _width, unsigned int _height)=0
Alert the window of a window resize event.
virtual void SetHandle(const std::string &_handle)=0
Set the window handle to attach the render window to.
virtual double DevicePixelRatio() const =0
Get the device to pixel ratio.
Definition: gz/rendering/Object.hh:34
virtual PixelFormat Format() const =0
virtual void SetWidth(const unsigned int _width)=0
virtual void RemoveRenderPass(const RenderPassPtr &_pass)=0
virtual void SetHeight(const unsigned int _height)=0
virtual void OnMove()=0
Alert the window of a window move event.
virtual void SetFormat(PixelFormat _format)=0
virtual unsigned int GLId() const =0
Returns the OpenGL texture Id. A valid Id is returned only.
