gz/rendering/base/BaseMesh.hh
STL class.
virtual bool HasSkeleton() const override
Check whether the mesh has skeleton.
Definition: gz/rendering/base/BaseMesh.hh:147
virtual unsigned int SubMeshCount() const override
Get the sub-mesh count.
Definition: gz/rendering/base/BaseMesh.hh:170
Definition: gz/rendering/base/BaseMesh.hh:259
virtual MaterialPtr Material() const override
Get the currently assigned material.
Definition: gz/rendering/base/BaseMesh.hh:321
bool ownsMaterial
Flag to indicate whether or not this submesh should be responsible for destroying the material.
Definition: gz/rendering/base/BaseMesh.hh:125
virtual bool HasSubMeshName(const std::string &_name) const override
Determine if has sub-mesh with given name.
Definition: gz/rendering/base/BaseMesh.hh:184
Definition: gz/rendering/base/BaseMesh.hh:95
MaterialPtr material
Pointer to currently assigned material.
Definition: gz/rendering/base/BaseMesh.hh:90
Definition: gz/rendering/Scene.hh:48
Definition: gz/rendering/base/BaseMesh.hh:128
Represents a collection of mesh geometries.
Definition: gz/rendering/Mesh.hh:35
virtual SubMeshPtr SubMeshByIndex(unsigned int _index) const override
Get sub-mesh at given index.
Definition: gz/rendering/base/BaseMesh.hh:198
BaseSubMesh()
Definition: gz/rendering/base/BaseMesh.hh:272
virtual SubMeshPtr SubMeshByName(const std::string &_name) const override
Get sub-mesh with given name.
Definition: gz/rendering/base/BaseMesh.hh:191
virtual SubMeshStorePtr SubMeshes() const =0
virtual void PreRender()=0
Definition: gz/rendering/base/BaseMesh.hh:244
Definition: gz/rendering/base/BaseMesh.hh:34
STL class.
virtual ~BaseMesh()
Definition: gz/rendering/base/BaseMesh.hh:141
virtual MaterialPtr Material(const std::string &_name) const =0
Get material registered under the given name. If no material is registered under the given name,...
virtual std::map< std::string, math::Matrix4d > SkeletonLocalTransforms() const override
Get the skeleton local transforms.
Definition: gz/rendering/base/BaseMesh.hh:155
virtual void SetMaterial(const std::string &_name, bool _unique=true) override
Set the materials of this SubMesh. The specified material will be retrieved from the parent Scene....
Definition: gz/rendering/base/BaseMesh.hh:295
Definition: gz/rendering/base/BaseMesh.hh:328
Set the materials of this Geometry. The specified material will be retrieved from the parent Scene....
Definition: gz/rendering/base/BaseMesh.hh:214
Definition: gz/rendering/base/BaseMesh.hh:284
virtual ~BaseSubMesh()
Definition: gz/rendering/base/BaseMesh.hh:278
bool ownsMaterial
Flag to indicate whether or not this mesh should be responsible for destroying the material.
Definition: gz/rendering/base/BaseMesh.hh:87
virtual void SetSkeletonLocalTransforms(const std::map< std::string, math::Matrix4d > &_tfs) override
Set transforms for the skeleton.
Definition: gz/rendering/base/BaseMesh.hh:163
shared_ptr< Material > MaterialPtr
Shared pointer to Material.
Definition: gz/rendering/RenderTypes.hh:143
Definition: gz/rendering/Material.hh:47
virtual bool HasSubMesh(ConstSubMeshPtr _subMesh) const override
Determine if has given sub-mesh.
Definition: gz/rendering/base/BaseMesh.hh:177
virtual void SetMaterialImpl(MaterialPtr _material)=0
Engine implementation for setting the material of this SubMesh.
Definition: gz/rendering/base/BaseMesh.hh:205
virtual void DestroyMaterial(MaterialPtr _material)=0
Unregister and destroy a material.
