Base render pass that can be applied to a render target. More...
#include <BaseRenderPass.hh>
virtual ~BaseRenderPass ()
virtual ~RenderPass ()
 BaseRenderPass ()
bool afterStitching = false
 Flag tracking the current value of SetWideAngleCameraAfterStitching() More...
bool enabled = true
template<class T>
class gz::rendering::BaseRenderPass< T >
◆ BaseRenderPass()
BaseRenderPass
◆ ~BaseRenderPass()
~BaseRenderPass
◆ IsEnabled()
bool IsEnabled ( ) const
True if the render pass is enabled, false otherwise.
Implements RenderPass.
void PreRender ( const CameraPtr &  _camera)
◆ SetEnabled()
void SetEnabled ( bool  _enabled)
[in]_enabledTrue to enable the render pass, false to disable.
◆ SetWideAngleCameraAfterStitching()
void SetWideAngleCameraAfterStitching ( bool  _afterStitching)
This function controls whether the effect is applied to each 6 faces individually; or during the "stitching" pass.
The default setting depends on the RenderPass (e.g. LensFlare defaults to true)
Remarks
This setting must not be changed after adding the RenderPass to a Camera.
[in]_afterStitchingTrue if it should be done after stitching, False if it should be done to each of the 6 faces separately.
◆ WideAngleCameraAfterStitching()
bool WideAngleCameraAfterStitching ( ) const
The current value set by SetWideAngleCameraAfterStitching
◆ afterStitching
◆ enabled
bool enabled = true
