BaseRenderTexture< T > Class Template Reference
 BaseRenderTexture ()
 ~BaseRenderTexture () override
virtual unsigned int GLId () const override
virtual void MetalId (void *_textureIdPtr) const override
 Gets the Metal texture id. A valid Id is obtained only if this is an Metal render texture. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease. More...
virtual ~RenderTexture ()
virtual ~RenderTarget ()
virtual bool Reinterpretable () const =0
 See SetFormat() More...
 Remove all render passes from the render target. More...
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false)=0
◆ BaseRenderTexture()
◆ ~BaseRenderTexture()
~BaseRenderTexture
◆ GLId()
unsigned int GLId ( ) const
Implements RenderTexture.
Reimplemented in Ogre2RenderTexture.
◆ MetalId()
void MetalId ( void *  _textureIdPtr) const
