RenderTexture Class Referenceabstract
Represents a off-screen render-texture to which cameras can render images. More...
#include <RenderTarget.hh>
virtual ~RenderTexture ()
virtual unsigned int GLId () const =0
virtual void MetalId (void *_textureIdPtr) const =0
 Gets the Metal texture id. A valid Id is obtained only if this is an Metal render texture. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease. More...
virtual ~RenderTarget ()
virtual bool Reinterpretable () const =0
 See SetFormat() More...
 Remove all render passes from the render target. More...
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false)=0
◆ ~RenderTexture()
virtual ~RenderTexture ( )
◆ GLId()
virtual unsigned int GLId ( ) const
Implemented in Ogre2RenderTexture, BaseRenderTexture< T >, BaseRenderTexture< OgreRenderTarget >, and BaseRenderTexture< Ogre2RenderTarget >.
◆ MetalId()
virtual void MetalId ( void *  _textureIdPtr) const
