Ogre 2.x implementation of the point light class. More...
#include <Ogre2Light.hh>
virtual ~Ogre2PointLight ()
- Public Member Functions inherited from BasePointLight< Ogre2Light >
virtual ~BasePointLight ()
- Public Member Functions inherited from PointLight
virtual ~PointLight ()
virtual ~Light ()
virtual ~Ogre2Light ()
 Destroy the light. More...
 ~BaseLight () override
void SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) override
void SetSpecularColor (double _r, double _g, double _b, double _a=1.0) override
virtual ~Ogre2Node ()
 Ogre2PointLight ()
- Protected Member Functions inherited from BasePointLight< Ogre2Light >
 BasePointLight ()
 Ogre2Light ()
 Initialize the light. More...
 BaseLight ()
 Ogre2Node ()
 Set the parent node. More...
double attenConstant = 1.0
double attenLinear = 0.0
double attenQuadratic = 0.0
double attenRange = 100.0
 Attenuation range. More...
 Light type. More...
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2PointLight()
Ogre2PointLight ( )
◆ ~Ogre2PointLight()
virtual ~Ogre2PointLight ( )
