Ogre2.x implementation of the mesh factory class. More...
#include <Ogre2MeshFactory.hh>
 Ogre2MeshFactory (Ogre2ScenePtr _scene)
virtual ~Ogre2MeshFactory ()
virtual void Clear ()
 Cleanup and clear all internal ogre v2 meshes created by this factory.
void ClearMaterialsCache (const std::string &_name)
 Remove internal material cache for a specific material.
virtual Ogre2MeshPtr Create (const MeshDescriptor &_desc)
 Create a mesh from a descriptor.
virtual bool IsLoaded (const MeshDescriptor &_desc)
 Check if the mesh is loaded using a mesh descriptor.
virtual bool Load (const MeshDescriptor &_desc)
 Load a mesh using a mesh descriptor.
virtual bool LoadImpl (const MeshDescriptor &_desc)
 Helper function to load the mesh from the input mesh descriptor.
virtual std::string MeshName (const MeshDescriptor &_desc)
 Get the mesh name from the mesh descriptor.
virtual Ogre::Item * OgreItem (const MeshDescriptor &_desc)
 Get the ogre item based on the mesh descriptor.
virtual bool Validate (const MeshDescriptor &_desc)
 Validate the mesh descriptor to make sure it contains all the needed information to create a mesh.
std::vector< std::string > ogreMeshes
 A list of ogre meshes created by this factory.
 Pointer to the scene object.
◆ Ogre2MeshFactory()
Ogre2MeshFactory ( Ogre2ScenePtr  _scene)
◆ ~Ogre2MeshFactory()
virtual ~Ogre2MeshFactory ( )
◆ Clear()
virtual void Clear ( )
◆ ClearMaterialsCache()
void ClearMaterialsCache ( const std::string &  _name)
Todo:
(iche033) Deprecate this function in gz-rendering10
◆ Create()
virtual Ogre2MeshPtr Create ( const MeshDescriptor &  _desc)
[in]_descMesh descriptor containing data needed to create a mesh
◆ IsLoaded()
virtual bool IsLoaded ( const MeshDescriptor &  _desc)
[in]_descMesh descriptor containing the mesh name used by this function for checking the loaded state
◆ Load()
virtual bool Load ( const MeshDescriptor &  _desc)
◆ LoadImpl()
virtual bool LoadImpl ( const MeshDescriptor &  _desc)
[in]_descInput mesh descriptor
◆ MeshName()
virtual std::string MeshName ( const MeshDescriptor &  _desc)
◆ OgreItem()
virtual Ogre::Item * OgreItem ( const MeshDescriptor &  _desc)
[in]_descDescriptor describing the target mesh
◆ Validate()
virtual bool Validate ( const MeshDescriptor &  _desc)
[in]_descMesh descriptor to be validated
◆ ogreMeshes
std::vector<std::string> ogreMeshes
◆ scene
Ogre2ScenePtr scene
