MeshDescriptor Struct Reference
Describes how a Mesh should be loaded. More...
#include <MeshDescriptor.hh>
 MeshDescriptor ()
 MeshDescriptor (const common::Mesh *_mesh)
 MeshDescriptor (const std::string &_meshName)
 Constructor. A common::Mesh will be retrieved from the MeshManager by the given name upon a call to Normalize.
void Load ()
 Ensures both the meshName and mesh member variables have been assigned. If mesh is not null, it will be used to override the value of meshName.
Public Attributes
bool centerSubMesh = false
 Denotes if the loaded sub-mesh vertices should be centered.
const common::Mesh * mesh = nullptr
 common::Mesh object
std::string meshName
 Name of the registered Mesh.
std::string subMeshName
 Name of the sub-mesh to be loaded. An empty string signifies all sub-meshes should be loaded.
gz/rendering/MeshDescriptor.hh
◆ MeshDescriptor() [1/3]
◆ MeshDescriptor() [2/3]
MeshDescriptor ( const std::string &  _meshName)
[in]_meshNameName of the mesh to load
◆ MeshDescriptor() [3/3]
MeshDescriptor ( const common::Mesh *  _mesh)
[in]_meshMesh to load
◆ Load()
void Load ( )
◆ centerSubMesh
◆ mesh
const common::Mesh* mesh = nullptr
common::Mesh object
◆ meshName
◆ subMeshName
