SegmentationCamera Class Referenceabstract
Poseable Segmentation camera used for rendering the scene graph. This camera is designed to produce segmentation data, instead of a 2D image. More...
#include <SegmentationCamera.hh>
virtual ~SegmentationCamera ()
virtual const math::Color & BackgroundColor () const =0
 Get color for background & unlabeled items in the colored map.
virtual int BackgroundLabel () const =0
 Get label for background & unlabeled items in the semantic map.
virtual gz::common::ConnectionPtr ConnectNewSegmentationFrame (std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0
 Connect to the new Segmentation image event.
virtual void CreateSegmentationTexture ()=0
 Create a texture which will hold the segmentation data.
virtual void EnableColoredMap (bool _enable)=0
 Enable Color map mode to generate colored semantics.
virtual bool IsColoredMap () const =0
 Check if color map mode is enabled.
virtual void LabelMapFromColoredBuffer (uint8_t *_labelBuffer) const =0
 Convert the colored map stored in the internal buffer to label IDs map, so users get both the colored map and the corresponding IDs map. This function must be called before the next render loop and the colored map mode must be enabled.
virtual uint8_t * SegmentationData () const =0
 Get the segmentation image data. If the segmentation type is panoptic, the first two channels are the instance count, and the last channel is the label.
virtual void SetBackgroundColor (const math::Color &_color)=0
 Set color for background & unlabeled items in the colored map.
virtual void SetBackgroundLabel (int _label)=0
 Set label for background & unlabeled items in the semantic map.
virtual void SetSegmentationType (SegmentationType _type)=0
 Set Segmentation Type.
virtual SegmentationType Type () const =0
 Get Segmentation Type.
virtual ~Camera ()
 Create a render window.
virtual void PrepareForExternalSampling ()=0
virtual void Render ()=0
 Get a render passes by index.
virtual void RenderTextureMetalId (void *_textureIdPtr) const =0
virtual void SetImageFormat (PixelFormat _format, bool _reinterpretable=false)=0
 Set the image pixel format.
virtual void Update ()=0
virtual VisualPtr VisualAt (const gz::math::Vector2i &_mousePos)=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
gz/rendering/SegmentationCamera.hh
◆ ~SegmentationCamera()
virtual ~SegmentationCamera ( )
◆ BackgroundColor()
virtual const math::Color & BackgroundColor ( ) const
Color of background & unlabeled items
Implemented in BaseSegmentationCamera< T >, and BaseSegmentationCamera< Ogre2Sensor >.
◆ BackgroundLabel()
virtual int BackgroundLabel ( ) const
label of background & unlabeled items
◆ ConnectNewSegmentationFrame()
virtual gz::common::ConnectionPtr ConnectNewSegmentationFrame ( std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberSubscriber callback function. The callback function arguments are: <segmentation data, width, height, channels, format>
Implemented in BaseSegmentationCamera< T >, BaseSegmentationCamera< Ogre2Sensor >, and Ogre2SegmentationCamera.
◆ CreateSegmentationTexture()
virtual void CreateSegmentationTexture ( )
Implemented in Ogre2SegmentationCamera, BaseSegmentationCamera< T >, and BaseSegmentationCamera< Ogre2Sensor >.
◆ EnableColoredMap()
virtual void EnableColoredMap ( bool  _enable)
[in]_enableTrue to generate colored map, False to generate label id map
◆ IsColoredMap()
virtual bool IsColoredMap ( ) const
True if colored map, False if label id map
◆ LabelMapFromColoredBuffer()
virtual void LabelMapFromColoredBuffer ( uint8_t *  _labelBuffer) const
[out]_labelBufferA buffer that is populated with the label IDs map data. This output buffer must be allocated with the same size before calling
◆ SegmentationData()
virtual uint8_t * SegmentationData ( ) const
The labels-buffer as an array of unsigned ints
◆ SetBackgroundColor()
[in]_colorColor of background & unlabeled items
◆ SetBackgroundLabel()
virtual void SetBackgroundLabel ( int  _label)
[in]_labellabel of background & unlabeled items
◆ SetSegmentationType()
virtual void SetSegmentationType ( SegmentationType  _type)
[in]_typeSegmentation Type
◆ Type()
virtual SegmentationType Type ( ) const
Segmentation Type
