Gazebo Sensors
ForceTorqueSensor Class Reference
Force Torque Sensor Class. More...
#include <ForceTorqueSensor.hh>
 ForceTorqueSensor ()
 constructor More...
virtual ~ForceTorqueSensor ()
 destructor More...
math::Vector3d Force () const
 Get the current joint force. More...
bool HasConnections () const
virtual bool Init () override
math::Quaterniond RotationChildInSensor () const
 Set the rotation of the joint parent relative to the sensor frame. More...
math::Quaterniond RotationParentInSensor () const
void SetForce (const math::Vector3d &_force)
 Set the force vector in sensor frame and where the force is applied on the child (parent-to-child) More...
void SetRotationChildInSensor (const math::Quaterniond &_rotChildInSensor)
 Set the rotation of the joint child relative to the sensor frame. More...
void SetRotationParentInSensor (const math::Quaterniond &_rotParentInSensor)
void SetTorque (const math::Vector3d &_torque)
 Set the torque vector in sensor frame and where the torque is applied on the child (parent-to-child) More...
math::Vector3d Torque () const
 Get the current joint torque. More...
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
 Sensor ()
 constructor More...
A force-torque Sensor that reports force and torque applied on a joint.
◆ ForceTorqueSensor()
constructor
◆ ~ForceTorqueSensor()
virtual ~ForceTorqueSensor ( )
destructor
◆ Force()
math::Vector3d Force ( ) const
The latest measured force.
◆ HasConnections()
bool HasConnections ( ) const
Todo:
virtual bool Init ( )
True on success
Reimplemented from Sensor.
◆ Load() [1/2]
◆ Load() [2/2]
◆ RotationChildInSensor()
math::Quaterniond RotationChildInSensor ( ) const
The current rotation the child in the sensor frame.
◆ RotationParentInSensor()
math::Quaterniond RotationParentInSensor ( ) const
The current rotation the parent in the sensor frame.
◆ SetForce()
void SetForce ( const math::Vector3d &  _force)
[in]_forceforce vector in newton.
◆ SetRotationChildInSensor()
void SetRotationChildInSensor ( const math::Quaterniond &  _rotChildInSensor)
[in]_rotChildInSensorRotation of child in sensor frame.
◆ SetRotationParentInSensor()
void SetRotationParentInSensor ( const math::Quaterniond &  _rotParentInSensor)
[in]_rotParentInSensorRotationof parent in sensor frame.
◆ SetTorque()
void SetTorque ( const math::Vector3d &  _torque)
[in]_torquetorque vector in newton.
◆ Torque()
math::Vector3d Torque ( ) const
The latest measured torque.
[in]_nowThe current time
Implements Sensor.
