Gazebo Sensors
gz/sensors/ForceTorqueSensor.hh
16 */
17
18 #ifndef IGNITION_SENSORS_FORCETORQUESENSOR_HH_
19 #define IGNITION_SENSORS_FORCETORQUESENSOR_HH_
20
21 #include <memory>
22
23 #include <sdf/sdf.hh>
24
25 #include <ignition/common/SuppressWarning.hh>
26 #include <ignition/common/Time.hh>
27
28 #include <ignition/math/Pose3.hh>
29
32
34
35 namespace ignition
36 {
37  namespace sensors
38  {
39  // Inline bracket to help doxygen filtering.
40  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
41  //
43  class ForceTorqueSensorPrivate;
44
48  class IGNITION_SENSORS_FORCE_TORQUE_VISIBLE ForceTorqueSensor
49  : public Sensor
50  {
52  public: ForceTorqueSensor();
53
55  public: virtual ~ForceTorqueSensor();
56
60  public: virtual bool Load(const sdf::Sensor &_sdf) override;
61
65  public: virtual bool Load(sdf::ElementPtr _sdf) override;
66
69  public: virtual bool Init() override;
70
74  public: virtual bool Update(
75  const std::chrono::steady_clock::duration &_now) override;
76
79  public: math::Vector3d Force() const;
80
84  public: void SetForce(const math::Vector3d &_force);
85
88  public: math::Vector3d Torque() const;
89
93  public: void SetTorque(const math::Vector3d &_torque);
94
98  public: math::Quaterniond RotationParentInSensor() const;
99
104  const math::Quaterniond &_rotParentInSensor);
105
109  public: math::Quaterniond RotationChildInSensor() const;
110
115  const math::Quaterniond &_rotChildInSensor);
116
120  public: bool HasConnections() const;
121
122  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
126  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
127  };
128  }
129  }
130 }
131
132 #endif
Force Torque Sensor Class.
Definition: gz/sensors/ForceTorqueSensor.hh:50
Set the force vector in sensor frame and where the force is applied on the child (parent-to-child)
Set the rotation of the joint parent relative to the sensor frame.
destructor
void SetRotationChildInSensor(const math::Quaterniond &_rotChildInSensor)
Set the rotation of the joint child relative to the sensor frame.
Get the current joint force.
virtual bool Update(const std::chrono::steady_clock::duration &_now) override
void SetRotationParentInSensor(const math::Quaterniond &_rotParentInSensor)
Get the current joint torque.
Set the torque vector in sensor frame and where the torque is applied on the child (parent-to-child)
a base sensor class
Definition: gz/sensors/Sensor.hh:60
