Gazebo Sensors
gz/sensors/GpuLidarSensor.hh
16 */
17 #ifndef GZ_SENSORS_GPULIDARSENSOR_HH_
18 #define GZ_SENSORS_GPULIDARSENSOR_HH_
20 #include <memory>
21 #include <string>
22
23 #include <sdf/sdf.hh>
24
25 #include <gz/common/SuppressWarning.hh>
26
27 // TODO(louise) Remove these pragmas once ign-rendering is disabling the
28 // warnings
29 #ifdef _WIN32
30 #pragma warning(push)
31 #pragma warning(disable: 4251)
32 #endif
33 #include <gz/rendering/GpuRays.hh>
34 #ifdef _WIN32
35 #pragma warning(pop)
36 #endif
37
38 #include "gz/sensors/gpu_lidar/Export.hh"
40 #include "gz/sensors/Lidar.hh"
41
42 namespace ignition
43 {
44  namespace sensors
45  {
46  // Inline bracket to help doxygen filtering.
47  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
48  //
50  class GpuLidarSensorPrivate;
51
61  class IGNITION_SENSORS_GPU_LIDAR_VISIBLE GpuLidarSensor : public Lidar
62  {
64  public: GpuLidarSensor();
65
67  public: virtual ~GpuLidarSensor();
68
72  public: virtual bool Update(
73  const std::chrono::steady_clock::duration &_now) override;
74
77  public: virtual bool Init() override;
78
82  public: virtual bool Load(const sdf::Sensor &_sdf) override;
83
87  public: virtual bool Load(sdf::ElementPtr _sdf) override;
88
90  public: virtual bool CreateLidar() override;
91
94  public: bool IsHorizontal() const;
95
98  public: void SetScene(gz::rendering::ScenePtr _scene) override;
99
102  public: void RemoveGpuRays(gz::rendering::ScenePtr _scene);
103
106  public: gz::rendering::GpuRaysPtr GpuRays() const;
107
114  public: double RayCountRatio() const;
115
118  public: gz::math::Angle HFOV() const;
119
122  public: gz::math::Angle VFOV() const;
123
127  public: bool HasConnections() const;
128
131  public: virtual gz::common::ConnectionPtr ConnectNewLidarFrame(
132  std::function<void(const float *_scan, unsigned int _width,
133  unsigned int _heighti, unsigned int _channels,
134  const std::string &/*_format*/)> _subscriber) override;
135
138  private: void OnNewLidarFrame(const float *_scan, unsigned int _width,
139  unsigned int _heighti, unsigned int _channels,
140  const std::string &_format);
141
142  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
146  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
147  };
148  }
149  }
150 }
151
152 #endif
GpuLidar Sensor Class.
Definition: gz/sensors/GpuLidarSensor.hh:62
Get the horizontal field of view of the laser sensor.
virtual gz::common::ConnectionPtr ConnectNewLidarFrame(std::function< void(const float *_scan, unsigned int _width, unsigned int _heighti, unsigned int _channels, const std::string &)> _subscriber) override
Connect function pointer to internal GpuRays callback.
Makes possible to change sensor scene.
Remove sensor from scene.
Return the ratio of horizontal ray count to vertical ray count.
Load sensor sata from SDF.
Create Lidar sensor.
virtual bool Update(const std::chrono::steady_clock::duration &_now) override
destructor
Gets if sensor is horizontal.
Get Gpu Rays object used in the sensor.
Lidar Sensor Class.
Definition: gz/sensors/Lidar.hh:50
