Gazebo Sensors
gz/sensors/LogicalCameraSensor.hh
16 */
17 #ifndef GZ_SENSORS_LOGICALCAMERASENSOR_HH_
18 #define GZ_SENSORS_LOGICALCAMERASENSOR_HH_
20 #include <map>
21 #include <memory>
22 #include <string>
23
24 #include <sdf/sdf.hh>
25
26 #include <gz/common/SuppressWarning.hh>
27
28 #include <gz/math/Angle.hh>
29
30 #ifdef _WIN32
31 #pragma warning(push)
32 #pragma warning(disable: 4005)
33 #pragma warning(disable: 4251)
34 #endif
35 #include <ignition/msgs.hh>
36 #ifdef _WIN32
37 #pragma warning(pop)
38 #endif
39
40 #include "gz/sensors/config.hh"
41 #include "gz/sensors/Export.hh"
42 #include "gz/sensors/logical_camera/Export.hh"
43 #include "gz/sensors/Sensor.hh"
44
45 namespace ignition
46 {
47  namespace sensors
48  {
49  // Inline bracket to help doxygen filtering.
50  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
51  //
53  class LogicalCameraSensorPrivate;
54
60  class IGNITION_SENSORS_LOGICAL_CAMERA_VISIBLE LogicalCameraSensor
61  : public Sensor
62  {
65
67  public: virtual ~LogicalCameraSensor();
68
72  public: virtual bool Load(sdf::ElementPtr _sdf) override;
73
76  public: virtual bool Init() override;
77
81  public: virtual bool Update(
82  const std::chrono::steady_clock::duration &_now) override;
83
87  public: double Near() const;
88
92  public: double Far() const;
93
97
102  public: gz::math::Angle HorizontalFOV() const;
103
107  public: double AspectRatio() const;
108
112  public: bool HasConnections() const;
113
117  public: msgs::LogicalCameraImage Image() const;
118
119  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
123  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
124  };
125  }
126  }
127 }
128
129 #endif
Logical Camera Sensor Class.
Definition: gz/sensors/LogicalCameraSensor.hh:62
Get the latest image. An image is an instance of msgs::LogicalCameraImage, which contains a list of d...
Get the aspect ratio, which is the width divided by height of the near or far planes.
double Near() const
Get the near distance. This is the distance from the frustum's vertex to the closest plane.
Get the horizontal field of view. The field of view is the angle between the frustum's vertex and the...
virtual bool Update(const std::chrono::steady_clock::duration &_now) override
destructor
void SetModelPoses(std::map< std::string, math::Pose3d > &&_models)
Set the models currently in the world.
double Far() const
Get the far distance. This is the distance from the frustum's vertex to the farthest plane.
a base sensor class
Definition: gz/sensors/Sensor.hh:60
