Gazebo Sensors
LogicalCameraSensor Class Reference
#include <LogicalCameraSensor.hh>
 LogicalCameraSensor ()
 constructor More...
virtual ~LogicalCameraSensor ()
 destructor More...
double AspectRatio () const
 Get the aspect ratio, which is the width divided by height of the near or far planes. More...
double Far () const
 Get the far distance. This is the distance from the frustum's vertex to the farthest plane. More...
bool HasConnections () const
gz::math::Angle HorizontalFOV () const
 Get the horizontal field of view. The field of view is the angle between the frustum's vertex and the edges of the near or far plane. This value represents the horizontal angle. More...
msgs::LogicalCameraImage Image () const
 Get the latest image. An image is an instance of msgs::LogicalCameraImage, which contains a list of detected models. More...
virtual bool Init () override
double Near () const
 Get the near distance. This is the distance from the frustum's vertex to the closest plane. More...
void SetModelPoses (std::map< std::string, math::Pose3d > &&_models)
 Set the models currently in the world. More...
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
 Sensor ()
 constructor More...
A logical camera reports locations of objects. This camera finds models within the sensor's frustum and publishes information about the models on the sensor's topic.
◆ LogicalCameraSensor()
constructor
◆ ~LogicalCameraSensor()
virtual ~LogicalCameraSensor ( )
destructor
◆ AspectRatio()
double AspectRatio ( ) const
The frustum's aspect ratio.
◆ Far()
double Far ( ) const
Far distance.
◆ HasConnections()
bool HasConnections ( ) const
Todo:
◆ HorizontalFOV()
gz::math::Angle HorizontalFOV ( ) const
The field of view.
◆ Image()
msgs::LogicalCameraImage Image ( ) const
List of detected models.
virtual bool Init ( )
True on success
Reimplemented from Sensor.
◆ Load()
◆ Near()
double Near ( ) const
Near distance.
◆ SetModelPoses()
void SetModelPoses ( std::map< std::string, math::Pose3d > &&  _models)
[in]_modelsA map of model names to their world pose.
[in]_nowThe current time
Implements Sensor.
