Gazebo Sensors
gz/sensors/ThermalCameraSensor.hh
16 */
17 #ifndef GZ_SENSORS_THERMALCAMERASENSOR_HH_
18 #define GZ_SENSORS_THERMALCAMERASENSOR_HH_
20 #include <memory>
21 #include <cstdint>
22 #include <string>
23
24 #include <sdf/sdf.hh>
25
26 #include <gz/common/Event.hh>
27 #include <gz/common/SuppressWarning.hh>
28
29 #ifdef _WIN32
30 #pragma warning(push)
31 #pragma warning(disable: 4005)
32 #pragma warning(disable: 4251)
33 #endif
34 #include <ignition/msgs.hh>
35 #ifdef _WIN32
36 #pragma warning(pop)
37 #endif
38
39 // TODO(louise) Remove these pragmas once ign-rendering is disabling the
40 // warnings
41 #ifdef _WIN32
42 #pragma warning(push)
43 #pragma warning(disable: 4251)
44 #endif
45 #include <gz/rendering/ThermalCamera.hh>
46 #ifdef _WIN32
47 #pragma warning(pop)
48 #endif
49
50 #include "gz/sensors/thermal_camera/Export.hh"
52 #include "gz/sensors/Export.hh"
53 #include "gz/sensors/Sensor.hh"
54
55 namespace ignition
56 {
57  namespace sensors
58  {
59  // Inline bracket to help doxygen filtering.
60  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
61  // forward declarations
62  class ThermalCameraSensorPrivate;
63
71  class IGNITION_SENSORS_THERMAL_CAMERA_VISIBLE ThermalCameraSensor
72  : public CameraSensor
73  {
76
78  public: virtual ~ThermalCameraSensor();
79
83  public: virtual bool Load(const sdf::Sensor &_sdf) override;
84
88  public: virtual bool Load(sdf::ElementPtr _sdf) override;
89
92  public: virtual bool Init() override;
93
97  public: virtual bool Update(
98  const std::chrono::steady_clock::duration &_now) override;
99
103  public: virtual rendering::ThermalCameraPtr ThermalCamera();
104
111  public: void OnNewThermalFrame(const uint16_t *_scan,
112  unsigned int _width, unsigned int _height,
113  unsigned int _channels,
114  const std::string &_format);
115
124  public: common::ConnectionPtr ConnectImageCallback(
125  std::function<void(const msgs::Image &)> _callback);
126
129  public: virtual void SetScene(
130  gz::rendering::ScenePtr _scene) override;
131
134  public: virtual unsigned int ImageWidth() const override;
135
138  public: virtual unsigned int ImageHeight() const override;
139
142  public: virtual void SetAmbientTemperature(float _ambient);
143
147  public: virtual void SetAmbientTemperatureRange(float _range);
148
151  public: virtual void SetMinTemperature(float _min);
152
155  public: virtual void SetMaxTemperature(float _max);
156
162  public: virtual void SetLinearResolution(float _resolution);
163
167  public: bool HasConnections() const;
168
171  private: bool CreateCamera();
172
176  private: void OnSceneChange(gz::rendering::ScenePtr /*_scene*/)
177  { }
178
179  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
183  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
184  };
185  }
186  }
187 }
188
189 #endif
Camera Sensor Class.
Definition: gz/sensors/CameraSensor.hh:72
Thermal camera sensor class.
Definition: gz/sensors/ThermalCameraSensor.hh:73
virtual void SetScene(gz::rendering::ScenePtr _scene) override
Set the rendering scene.
common::ConnectionPtr ConnectImageCallback(std::function< void(const msgs::Image &)> _callback)
Set a callback to be called when image frame data is generated.
Set the ambient temperature of the environment.
destructor
Get image height.
Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin ...
virtual bool Update(const std::chrono::steady_clock::duration &_now) override
Set the range of ambient temperature.
Set the maximum temperature the sensor can detect.
void OnNewThermalFrame(const uint16_t *_scan, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)
Thermal data callback used to get the data from the sensor.
Set the minimum temperature the sensor can detect.
Get image width.
