Gazebo Sensors
Camera Sensor Class. More...
#include <CameraSensor.hh>
 CameraSensor ()
 constructor More...
virtual ~CameraSensor ()
 destructor More...
double Baseline () const
bool HasConnections () const
bool HasImageConnections () const
 Check if there are any image subscribers. More...
bool HasInfoConnections () const
 Check if there are any info subscribers. More...
virtual unsigned int ImageHeight () const
 Get image height. More...
virtual unsigned int ImageWidth () const
 Get image width. More...
virtual bool Init () override
 Get the camera optical frame. More...
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
std::string FrameId () const
 FrameId. More...
SensorId Id () const
 Get the sensor's ID. More...
bool IsActive () const
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
void SetActive (bool _active)
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
bool AdvertiseInfo ()
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class creates images from an ignition rendering scene. The scene must be created in advance and given to Manager::Init(). It offers both an ignition-transport interface and a direct C++ API to access the image data. The API works by setting a callback to be called with image data.
◆ CameraSensor()
constructor
◆ ~CameraSensor()
virtual ~CameraSensor ( )
destructor
◆ AdvertiseInfo() [1/2]
bool AdvertiseInfo ( )
True if successful.
◆ AdvertiseInfo() [2/2]
bool AdvertiseInfo ( const std::string &  _topic)
[in]_topicThe topic on which camera info is to be published.
True if successful.
◆ Baseline()
double Baseline ( ) const
The distance from the 1st camera, in meters.
◆ ConnectImageCallback()
gz::common::ConnectionPtr ConnectImageCallback ( std::function< void(const gz::msgs::Image &)>  _callback)
Remarks
◆ HasConnections()
bool HasConnections ( ) const
Todo:
◆ HasImageConnections()
bool HasImageConnections ( ) const
True if there are image subscribers, false otherwise
Todo:
(iche033) Make this function virtual on Harmonic
◆ HasInfoConnections()
bool HasInfoConnections ( ) const
True if there are info subscribers, false otherwise
Todo:
◆ ImageHeight()
Get image height.
height of the image
Reimplemented in ThermalCameraSensor, SegmentationCameraSensor, RgbdCameraSensor, DepthCameraSensor, and BoundingBoxCameraSensor.
◆ ImageWidth()
Get image width.
width of the image
◆ InfoTopic()
std::string InfoTopic ( ) const
Camera info topic.
virtual bool Init ( )
True on success
Reimplemented from Sensor.
◆ Load() [1/2]
◆ Load() [2/2]
◆ OpticalFrameId()
const std::string& OpticalFrameId ( ) const
The camera optical frame
◆ PopulateInfo()
void PopulateInfo ( const sdf::Camera *  _cameraSdf)
[in]_cameraSdfPointer to SDF object containing camera information.
◆ PublishInfo()
void PublishInfo ( const std::chrono::steady_clock::duration &  _now)
[in]_nowThe current time
◆ RenderingCamera()
rendering::CameraPtr RenderingCamera ( ) const
Camera in Gazebo Rendering.
◆ SetBaseline()
void SetBaseline ( double  _baseline)
[in]_baselineThe distance from the 1st camera, in meters.
◆ SetScene()
Reimplemented in ThermalCameraSensor, RgbdCameraSensor, and DepthCameraSensor.
Implements Sensor.
